  #11
Old January 18th, 2011, 07:39 AM
jlogan's Avatar
jlogan jlogan is offline
jlogan is a Soldier
This is what I am using for the arms.
http://www.ballisticfabrication.com/...es_p_1246.html
You could just get the passenger side and use the stock Chevy drag link on the axle to save some money. I had a moment of weakness shopping online and went the more expensive route. This seems to keep happening with this project which is why I have started making posts in the for sale section.
Quote:
Originally Posted by Troop ISP View Post
The swap looks great. The thing I like the best is you have more room in the back to clear your brake calipers. Who did you get your high steer components from?
  #12
Old January 18th, 2011, 07:46 AM
jlogan's Avatar
jlogan is a Soldier
Quote:
Originally Posted by SVENG52 View Post
Wow awesome axle to swap in. I cant say those rears are easy to find thou.
They are out there, but it definitely isn't super common. When you find one it will probably be cheap. There aren't many applications for an axle this wide.
  #13
Old January 18th, 2011, 07:53 AM
SVENG52 SVENG52 is offline
Private 1st Class
SVENG52 is a Soldier
Quote:
Originally Posted by Grantshire View Post
Easier than you might think and can be pretty cheap. Most guys with CJ10A's scrap them because no one wants them.
Well if anyone stumbles across on in the northeast let me know. I would definitely do this swap
  #14
Old January 21st, 2011, 04:59 AM
4X4jeepfreak's Avatar
4X4jeepfreak 4X4jeepfreak is offline
4X4jeepfreak is a Soldier
The rear axle out of a chevy 1ton dually box van is the same axle,dana 70U.It will bolt rite in without moveing the spring mounts.You can even use the drum breaks if you want.
  #15
Old January 24th, 2011, 06:55 PM
jlogan's Avatar
jlogan is a Soldier
Quote:
Cool. Have you put this axle under your truck? I'm sure others would like to see some pics if you get a chance to post them up. How wide is the axle?
  #16
Old January 28th, 2011, 08:47 PM
jlogan's Avatar
jlogan is a Soldier
Here's a few pics with the truck back on its feet. 12 bolt H1 wheels (not re-centered) with the 37" H1 radials. Looks like the rear tires are just about even with the outside edge of the fender. I'll be picking it up at the end of next week and can take more detailed pictures if anyone wants any.
  #17
Old January 29th, 2011, 07:04 AM
Panther's Avatar
Panther Panther is offline
Private 1st Class
Panther is a Soldier
Looks like it was meant to be.
I think this is a great upgrade/set up for the axles, rims and tires. Good stuff
Sent from my SPH-M900 using Tapatalk
  #18
Old February 19th, 2011, 12:47 PM
jlogan's Avatar
jlogan is a Soldier
Here's another picture showing the outside of the tire in relation to the fender. The tread is inside the fender, but the sidewall bulges out just a little.
  #19
Old February 19th, 2011, 12:54 PM
jlogan's Avatar
jlogan is a Soldier
A few more pics.
  #20
Old May 7th, 2011, 02:17 PM
cleefurd's Avatar
cleefurd cleefurd is offline
cleefurd is a Soldier
OK quick question;
If this axle is 75.5" WMS to WMS with disc brakes... How would the M1008 Dana60 front at 69'ish WMS to WMS compliment this set-up using the HMMWV rims?
Would you use spacers up front so the track is the same front and rear?
I ask because I'm considering one of the CJ10A axles Grantshire sourced for us. The one in Houston is less than 600 miles from me, so I'm tempted to go this route instead of Rockwells. Options still open, but I like the idea of the tug axles making good use of the HMMWV back-spacing. Perhaps matching the width up front with spacers eliminates steering component interference on the M1008 axle when running HMMWV wheels???
My two oposing options are being weighed based on ;
  • The Dana axles with much lighter wheels and 37"ish tires would probably get much better milage with the 6BT at 1800 RPM than;
  • Rockwells and heavy 20" wheels with 43"ish tires geared towards the same 1800 RPM cruise speed
