  #31
Old May 10th, 2011, 04:46 PM
cleefurd's Avatar
cleefurd cleefurd is offline
cleefurd is a Soldier
Quote:
Originally Posted by glenn View Post
Maybe someone a little more computer literate than me can link that JP magazine article about their M-715 axle swap. It explains it pretty good I think. In fact maybe one of the mods could put it under the sticky about axle swaps.
What he said
  #32
Old May 10th, 2011, 05:18 PM
Panther's Avatar
Panther Panther is offline
Private 1st Class
Panther is a Soldier
A sticky would be good. Here's a couple links that might be helpful.
http://www.jpmagazine.com/techarticl...wap/index.html
Sent from my SPH-D700 using Tapatalk
  #33
Old May 13th, 2011, 09:55 AM
Panther's Avatar
Private 1st Class
Default more pics
Here's some pics from wanapinz and the set up on his 725. This gives an idea of the spring under front gm dana 60 with dually front hubs.
This is a great set up. However, I don't see how you can stay spring under and squeeze a 6bt in there.
  #34
Old May 13th, 2011, 04:52 PM
cleefurd's Avatar
3 Questions;
  • Are those NOS, refurb, or National/aftermarket springs?
  • Hoping the 6BT is do-able with this approach, since it's the only reason I'm not doing a spring over and Rockwells... in order to keep a low CG.
  • Is there a thread on this build? Assuming those are HMMWV wheels to be out that far.
  #35
Old May 13th, 2011, 06:16 PM
Panther's Avatar
Private 1st Class
Sorry for the large pics, don't know how to resize them.
There is a thread here My new project m725
Also for what you want to do, this build should gives you ideas My new project m725
  #36
Old July 8th, 2014, 07:49 PM
Mikel Mikel is offline
Sergeant
Mikel is a Soldier
I used a dana 70 from a 70s Chevy motorhome that was 72" WMS to WMS. Had 4.10s and fits quite nicely in a M715 with HMMWV rims. I did convert it to disks.
  #37
Old September 7th, 2017, 10:05 PM
skunkworks32's Avatar
skunkworks32 skunkworks32 is offline
Civilian
skunkworks32 is a Soldier
Default Cj10a
Does the Dana 70u from Jeep CJ10A Tug share the exact same spring perch as our M715?
  #38
Old September 8th, 2017, 05:30 AM
Grantshire's Avatar
Grantshire Grantshire is offline
Private 1st Class
Grantshire is a Soldier
Quote:
Don't believe it does. The CJ10A is a chopped Wagoneer frame and has the same rear width. J trucks had a wider frame in back. However, moving the perches out slightly is no big deal and the extra wide width of the CJ 10A Dana 70 makes it a great choice. The stock 4.88 gears with either a limited slip or locker are pluses as well.
  #39
Old September 9th, 2017, 07:57 PM
Civilian
Thanks for the info! I picked one up today, still looking for the front one.
  #40
Old September 10th, 2017, 06:21 PM
Civilian
Grantshire the Chevy DRW front Dana 60 is from a M1008 right? Does it line up well or will I have to do modifications?
