Old April 20th, 2004, 08:13 PM
compexp's Avatar
compexp compexp is offline
Sergeant
compexp is a Soldier
Default J-series wiper motors
While perusing my hood area today, I noticed that the vent grille has the same cutouts that my J-10 does. Has anyone transferred a J-series wiper assembly to the M-series.
Rich
Old April 21st, 2004, 04:53 AM
Mikel Mikel is offline
Sergeant
Mikel is a Soldier
I suspect the windshield angle might be a problem, even if the motor and linkages fit.
Old April 21st, 2004, 08:12 AM
k8icu's Avatar
k8icu k8icu is offline
Sergeant
k8icu is a Soldier
I would have to agree with that...The civilan window is at and angle and the gi one is flat. I would thing it would make it difficult for the wipers to do their job properly....but hey you can always try and let us know...
Zone holster maker
Old April 24th, 2004, 07:27 AM
65CJ5 65CJ5 is offline
65CJ5 is a Soldier
Default T98 Input
I prefer the look of the top mounted wipers myself. Best way to improve them while keeping them top-mounted is to use heavy duty marine wiper motors. They are not cheap, but they work great as a replacment for the old vac wipers.
Here's a link to the style most people use:
http://www.boatersworld.com/webapp/w...38&cat2=343437
You can do a web search on AFI WIPER and see a lot of links for them.
Stan
Old April 24th, 2004, 03:48 PM
topdog topdog is offline
New Recruit
topdog is a Soldier
Default Smooth Idle ,got Smoother???
If I remember right, JC Whitney sells 12 volt electric motors that will replace vacuum motors. I think the price was around $25 each. Might be worth a look.
Phil
  #6
Old April 25th, 2004, 04:15 AM
65CJ5 is a Soldier
Default M725 FOR SALE
Quote:
Phil
Phil, yes JCW carries them and so does 4WD Hardware and a number of others. The problem with those motors is they use small plastic gears inside that break easily. Also the cases aren't weather resistant so any water that gets on them usually gets inside ruining them. The cheap motors don't hold up nearly as well as the marine style.
Stan
  #7
Old April 25th, 2004, 07:51 AM
the1968jeepthing the1968jeepthing is offline
the1968jeepthing is a Soldier
could one use some sort of 12v vacume pump to power the existing ones? would it be worth the trouble?
BrianM
  #8
Old April 25th, 2004, 08:53 AM
Barrman's Avatar
Barrman Barrman is offline
Chief 9-flats
Barrman is a Soldier
That is what MCInfantry did. He got the electric pump from a early '90's Cadillac.
  #9
Old May 3rd, 2004, 10:25 PM
SHoppe SHoppe is offline
New Recruit
SHoppe is a Soldier
My idea for those civ wiper arm indentations is using them to locate washer fluid sprayers. Not being able to wash the window while driving really annoys me. Sound like an idea? Any takers?
  #10
Old May 3rd, 2004, 10:41 PM
New Recruit
SHoppe is a Soldier
Oh yeah, hoods... on the old message board I posted a message about using a civilian hood latch. Works great!!! Compare the mounts. Direct bolt-in on passenger side. Had to fish bolts under driver side mount on hood and nut the outsides. Only had to drill one hole for driver side locator post. Springs on posts work perfect and the safety hook hits the square hole and catches just right. Bent the release lever up so that it tucks under the lip on the front of the hood. I always hated that goofy second lever behind the grill on the civ latches. Now I'd have to break 5 latches for that hood to pop open by itself on the highway. This also really stiffens up the hood and will eliminate that split in the front center (you all know the one).
HTML code is On
Wiper motors Chumley Modified Tech 6 October 17th, 2007 08:25 PM
24V Heater Fan Motors Snuffy Open Discussion 5 July 12th, 2007 02:51 PM
Alternator rebuild series adk4x4 Stock Tech 1 January 10th, 2007 07:09 AM
