Go Back   M715 Zone > General Tech > Stock Tech > Stock Tech Archives
Stock Tech Archives Look here first for all archived messages
Old May 11th, 2004, 09:24 AM
law law is offline
Basic Trainee
law is a Soldier
Have any of you had problems w/ ignition coils? I have had two coils fail in 9,000 miles. Are these coils just crap or could there be something going on w/ my truck that is making them fail prematurely? Anybody know a good source for coils - I called AB Linn and he only has tiwan coils which he dose not recommend.
Old May 11th, 2004, 09:28 AM
Nuke_mcinfantry Nuke_mcinfantry is offline
Nuke_mcinfantry is an Observer
Default 24 Volt Replacement Ignition Coil
no usa coils are left...... i burned 3 in 2 months so i went diesel
1967 M-715 (A1)
www.homepage.mac.com/ltalessi
Old May 11th, 2004, 09:51 AM
Doug's Avatar
Doug Doug is offline
Das Fire Führer!
Doug is a Soldier
You may want to check other components also, cap, plugs wires.
If any of those are bad it will put more strain on the coil, May not remedy a cheaply made coil, but will help you get the most out of it.
doug
Old May 11th, 2004, 05:38 PM
k8icu's Avatar
k8icu k8icu is offline
Sergeant
k8icu is a Soldier
Make sure you don't leave your on/off switch on. That will burn out coils also.
Zone holster maker
Old May 12th, 2004, 09:33 AM
law law is offline
Basic Trainee
law is a Soldier
This last coil croaked while going down the expressway so it was not the on/off switch. Thank for suggestion though. I bought a replacement coil yesterday which I think may be NOS / USA (w/ external ballast resistor) from Saturn surplus - I'll know after it delivers. $48.00 plus shipping. Hopefully this one will last a while.
HTML code is On
New coil Anson Stock Tech 16 February 20th, 2020 06:33 AM
Is it possible to connect a converter to ignition coil RubyRed Modified Tech 2 April 21st, 2009 10:05 PM
12 volt tach, 24 volt system vacca rabite Modified Tech 1 May 19th, 2008 12:12 PM
Guage replacement-- 12 volt boghog Modified Tech 12 September 21st, 2007 06:58 AM
