Go Back   M715 Zone > General Tech > Stock Tech > Stock Tech Archives
Stock Tech Archives Look here first for all archived messages
Old May 16th, 2004, 08:08 PM
Nuke_uscgjason Nuke_uscgjason is offline
Civilian
Nuke_uscgjason is an Observer
Default Severe Grinding Noise Help.
Hello all,
I have a question for all of you. My 715 has started to emit a Grinding noise anytime I release the clutch or if I am driving anytime I let off on the gas. The grinding sounds as if it is coming from the transmission, as if the clutch may not be disengaging??? and maybe I am hearing the gears getting more backlash because of this. Anyway has anyone else encountered this problem? Maybe the Pilot bearing is going out or is gone. Im grasping here fellas, LOL. Any help is appreciated.
Thank you
Jason
Old May 16th, 2004, 08:11 PM
Nuke_mcinfantry Nuke_mcinfantry is offline
Nuke_mcinfantry is an Observer
sounds like clutch, or tob. (throwout bearing)
i hears its a to change the clutch
1967 M-715 (A1)
www.homepage.mac.com/ltalessi
Old May 17th, 2004, 08:56 AM
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
I would bet on he clutch plate or the throwout bearing....and you should plan on changing it SOON!!
Old May 18th, 2004, 01:56 PM
law law is offline
Basic Trainee
law is a Soldier
Sounds like a F-350 I use to own. When I took it apart, 50% of the springs in the clutch disk were broken. At that time, I had to replace the clutch, pressure plate and flywheel. The springs ate the hell out of them as they were breaking up.
Old May 23rd, 2004, 06:37 PM
Civilian
Default half tops.
Is our clutch the same as the civilian version for the gladiator or do I need to hunt up a special one from somewhere. Thanks for all of your help guys, this site rocks
Jason
  #6
Old May 24th, 2004, 12:18 PM
brute4c's Avatar
Grand Poobah
Default two nice tow rigs!
It is the same....I recently bought a clutch and pressure plate....beleive it or not NAPA had the best price easily....
Ask for a 64 or 65 Gladiator pickup with a 230 and an 11 inch clutch. I think one was $45 and one was $55....not bad really...
If you need the throwout bearing too, then you can get a kit at AutoZone, clutch, pressure plate and throwout bearing. NAPA has the throwout bearing but its more expensive to buy the 3 pieces from them....the bearing was over $70 at NAPA by itself....the Autozone kit is around $150....
Hope that helps....I posted the parts numbers on the board here when I bought them...a search should turn them up.
HTML code is On
Third Gear Noise Pineyguy Open Discussion 8 March 8th, 2009 05:24 PM
Clutch noise? ralph Modified Tech 4 February 22nd, 2009 08:43 PM
strange noise stranman Stock Tech 16 October 1st, 2008 08:17 AM
What's that noise? white433 Modified Tech 1 January 13th, 2008 04:56 PM
