Go Back   M715 Zone > General Tech > Stock Tech > Stock Tech Archives
Stock Tech Archives Look here first for all archived messages
Old May 18th, 2004, 04:08 PM
Nuke_FFF Nuke_FFF is offline
Civilian
Nuke_FFF is an Observer
Did those of you with the civvy distributor use a ballast resistor or are you using full 12volts? I got the cap, rotor and points at NAPA but need to know about the voltage. Thanks in advance and if anyone needs the part
#s let me know.
FFF
Old May 18th, 2004, 04:15 PM
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
Default Question about civvy distributor
I have not used a ballast resistor with mine....although I probably should....the civvy vehicle it came out of had a ballast resistor, which I still have somewhere, so I would bet it was designed to be there....though I have had mine in there for several years, I have roughly 8000 miles or so on it....2nd cap and first points....only changed the cap because it was WET from deep water racing at FE99...changed it right there...so I havent really notoed any negative problems...but still it was designed for it.....
The Napa part numbers for the civvy ignition cap, rotor, points, condensor, and primary wire are in the parts list in the online manuals section linked at left.
Old May 18th, 2004, 04:17 PM
LuckyPabst's Avatar
LuckyPabst LuckyPabst is offline
Private 1st Class
LuckyPabst is a Soldier
Ballast resistor is matched to the coil. Points don't care what voltage they get. Either the coil is internally or externally resisted. Ultimately you want total resistance to add up to around 1.5 ohms (not certain on that number, it's off the top of my head).
A safe bet is when you buy a new coil, buy the resistor that is matched to it, unless it's internally resisted in which case you don't need one.
Chris
Old May 18th, 2004, 05:14 PM
brute4c's Avatar
Grand Poobah
Default winch assembly
I am using the coil that came with the 230 engine I got the dist from.....
Old May 18th, 2004, 05:27 PM
LuckyPabst's Avatar
Private 1st Class
I'm just saying how the system should be set up. Without enough resistance in the system you'll probably see shorter coil and points life.
But yea, it'll work great and start easy without the resistor.
Chris
  #6
Old May 19th, 2004, 01:01 PM
Civilian
Thanks both of you for your input, it will be a big help.
FFF
  #7
Old May 19th, 2004, 07:46 PM
05strokinfx4 05strokinfx4 is offline
Civilian
05strokinfx4 is an Observer
what are the part#'s for the distributor cap and rotor
  #8
Old May 20th, 2004, 08:10 AM
brute4c's Avatar
Grand Poobah
Civilian or military....the civvy stuff is listed in the M715 Parts list which is linked in the Online Manuals linked at left.
  #9
Old May 20th, 2004, 06:55 PM
Civilian
Brute's right, the #s on the parts list match what I got.
cap #AL128
rotor #AL107
FFF
HTML code is On
brute4c : A different civvy wire conversion... brute4c PseudoZone - Mod Tech Archive 0 December 15th, 2009 05:05 PM
Civvy intake Pineyguy Modified Tech 7 November 12th, 2009 04:19 AM
civvy hood CHRIS UNGER Open Discussion 5 February 23rd, 2009 10:48 PM
Civvy Distributor Timing rboltz Modified Tech 15 April 8th, 2008 07:35 AM
PCV Valve w/Civvy Intake Manifold rboltz Modified Tech 6 March 31st, 2008 12:20 PM
