Go Back   M715 Zone > General Tech > Stock Tech > Stock Tech Archives
Stock Tech Archives Look here first for all archived messages
  #11
Old May 18th, 2004, 08:06 PM
Nuke_mcinfantry Nuke_mcinfantry is offline
Nuke_mcinfantry is an Observer
yes about 15000 gets me to 70mph. its not worth it to go any faster
1967 M-715 (A1)
www.homepage.mac.com/ltalessi
  #12
Old May 18th, 2004, 08:39 PM
k8icu's Avatar
k8icu k8icu is offline
Sergeant
k8icu is a Soldier
McInf did you put power steering in your truck?
Zone holster maker
  #13
Old May 18th, 2004, 08:53 PM
yeah. power steering along w/power brakes and im trying to mount the hydro ram assist befire the FE
1967 M-715 (A1)
  #14
Old May 19th, 2004, 11:34 AM
M715up M715up is offline
Banned
M715up is an Observer
On the Novak Conversions site they say that if you have a higher (smaller number) gear ratio than you need to change the carrier along with the ring and pinion, is that true?
  #15
Old May 19th, 2004, 01:47 PM
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
The stock setup will handle ratios that are 4.56 or lower, numerically higher, gear ratio...to go past 4.56, you need a new carrier....note that the carries for the higher gears and the lower gears each will hold the 4.56 gears but you gotta specifiy which one you have...the higher gear or lower gear one....
So there is one from 2.xx gears to 4.56 and one from 4.56 to 7.xx
  #16
Old May 19th, 2004, 03:17 PM
Banned
Do you know what trucks I could get this ring and pinion and carrier out of?
  #17
Old May 19th, 2004, 04:23 PM
brute4c's Avatar
Grand Poobah
no I dont...maybe someone else will....
  #18
Old May 22nd, 2004, 04:41 PM
Banned
Would it just be better to take the cab and bed of the M715 and put it on a chevy or ford chassias? In that case you get power steering,better highway speeds and other stuff.
  #19
Old May 22nd, 2004, 05:19 PM
dave's Avatar
dave dave is offline
Private 1st Class
dave is an Observer
basically thats what you do when you modify one to get faster speeds out of it is use donor parts truck. you change engines, trans, diffs,transfer cases, ect. you would be ahead to find a donor truck if you want to go faster on the highway. with the 715/724/725/726's they werent made to go fast just go anywhere and carry heavy loads doing it. you will then lose the thing that makes these trucks special in that you lose that rock crawling, stump pulling, low geared ability that these trucks were made for. you can change the tranny to an overdrive and then you would need to change the transfer case as they heat up at speed and from what the guys say get extremely hot. then you would be able to keep your low gears and still get highway speeds. basically its what ever you plan on using it for that determines what you do with it, stock or modified, fast or slow speeds, ect.
67 M725, 67 M715, 68 M715
  #20
Old May 22nd, 2004, 07:38 PM
brute4c's Avatar
Grand Poobah
In my opinion...
If you want an M715 you want lower highway speeds, bottom end gearing.....brute force.....
If ya want a factory type pickup that looks like an M715, put the cab and bed on their frame....
Then theres that "other world"...modify the M715 with new drivetrain components but do it in a way that gives you low gears AND highway speeds higher than stock AND upgrade the surrounding systems to be up to the task....
Ideally for me, the first and the 3rd above....one of each, would be my choices...and so thats my goal...yours will vary I'm sure!!
brute4
HTML code is On
pics of 39's on stock M715 FSJ Super Swamper Modified Tech 25 May 15th, 2009 10:06 AM
highway speed issues. xownzux Modified Tech 17 March 30th, 2009 06:41 AM
Stock Rims M715 vs. M37... rip68 Stock Tech 5 January 28th, 2008 08:59 PM
Locking Hubs-for a stock M715-What is everyone using? Nuke_Danarchy Modified Tech Archives 13 April 29th, 2004 05:16 PM
