Old May 19th, 2004, 08:28 PM
Private 1st Class
Rockwell non steer rear alxe.
Housing alone: 145Lbs.
Chunk/diff section: 215Lbs. (with detroit, same as front section)
Hubs: 35Lbs each. (same as front)
My calcs could put together a rockwell rear for around 600-700Lbs with aftermarket brakes.
Sorry I don't have a weight for the front housing...was so excited to finally have parts I slapped it back together. I'll try and get a total weight at a later time for the steer rear.
Big Blocks RULE!
Old May 20th, 2004, 06:27 AM
rollie715's Avatar
rollie715 rollie715 is offline
rollie715 is a Soldier
Any idea how that compares to our stock m715 rear Dana 70?
Rollie
Old May 20th, 2004, 07:36 AM
Private 1st Class
I've seen posts as high as 800LBS on D70's and 14 bolts. I don't have that exact info though. I should weigh one of the rockwell drum and backing assy's and see how much is lost with just them. it's a bunch though!
Big Blocks RULE!
Old May 20th, 2004, 07:57 AM
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
Chad told me that when they took the drum stuff off his Rockwells, they saved 185 pounds....I think that was per side...but maybe both.....
Old May 20th, 2004, 02:41 PM
Private 1st Class
That was both sides together. I can pick up drum, and fully assembled backing plate...but it's heavy. Around 90Lbs a side feels about right. The 215Lb chunk is a handful though. I have it sitting on the floor on two pieces of 2x6. I roll the floor jack over then squat down and pick it up just enough to swing it back and dump it on the jack. WHEW! I've got a forklift attachment made up for the John Deere and I'll have the housing upside down on that then roll the chunk under that and let the housing down over it. That's how I assembled the front and test fit the pan for the rear after welding up the hole and grinding extra clearance at the sides. sheesh.
Big Blocks RULE!
HTML code is On
empty weight Hammered Stock Tech 5 January 15th, 2010 06:23 AM
d60 / 14 weight noreallyicanfixit Open Discussion 10 December 3rd, 2009 06:13 PM
M725 max weight ??? Jim Hunter Stock Tech 8 November 19th, 2009 08:40 PM
foreverunstopable : Lav Weight PseudoZone PseudoZone - Open Archive 2 November 11th, 2009 10:38 PM
weight of the m715? Agent Orange Stock Tech 6 July 18th, 2009 06:48 AM
