Go Back   M715 Zone > General Tech > Stock Tech > Stock Tech Archives
Stock Tech Archives Look here first for all archived messages
Old May 20th, 2004, 06:55 AM
Brian Sisson Brian Sisson is offline
Brian Sisson is a Soldier
(I called it that so you northerners would know what I was talking about)
How much slack do you have in it? If I put mine in neutral and crawl underneath and turn the driveshaft I get about 1/8th of a turn out of it before it tightens up.
The front-rear gives me about 1/10th of a turn.
Is this normal?
I have a locker in the rear, and when I installed it the ring and pinion looked fine and had no wear patterns I could see.
Seems like alot of slack to me.
Also, on a related note- when I'm cruising at 55 or so sometimes I get a whine out of my axle. Not really loud, but noticeable. All 3 of my 715's have had that and I assumed it was just part of their set-up. Do you guys get it?
I'm just getting paranoid as the big drive is coming up.
Thanks,
-B.
Old May 20th, 2004, 03:33 PM
Nuke_GreenMachine Nuke_GreenMachine is offline
Basic Trainee
Nuke_GreenMachine is an Observer
If you put the Detroit No-slip or a Detroit locker in, the freeplay is normal. The whine I think you will find is in the transfer case and not in the rear axle, or rear-rear axle to some. :P Glen
Proud owner of two 1968 M0715 trucks....
Maybe they own me....or soon will!
Old May 20th, 2004, 03:38 PM
LuckyPabst's Avatar
LuckyPabst LuckyPabst is offline
Private 1st Class
LuckyPabst is a Soldier
Big drive my foot. It's a cake walk for you man. I'm moving farther and farther from making the comittment to make the FE, by the way.
Chris
Old May 20th, 2004, 06:55 PM
Default I'm offended Tom is not here....
Chris,
Rehab is full of guys like you.
Quitters.
You make me sick with your selfish unattendance of our gathering.
-B.
Old May 21st, 2004, 03:16 AM
hkellerjr's Avatar
hkellerjr hkellerjr is offline
New Recruit
hkellerjr is an Observer
Quote:
What type of extra parts do you recommended taking on long trips?
  #6
Old May 21st, 2004, 05:06 AM
You prolly need to start this as a new thread in the OPEN board....just to keep things organized. Alot of guys will want to discuss this and thus it was a good topic to bring up.
Start the new thread NOW!!!!
-B.
HTML code is On
Rear axle and hub removal Beachtruck Stock Tech 9 May 20th, 2009 05:58 AM
Rear Axle Leak rboltz Stock Tech 8 March 11th, 2009 11:06 AM
Help please...rear axle removal.... ChalkOutline Stock Tech 4 October 8th, 2007 09:51 PM
Need a rear axle pinion nut. TheWarTapes Stock Tech 1 March 6th, 2007 05:10 PM
