Old May 21st, 2004, 09:03 AM
bggrntrk bggrntrk is offline
bggrntrk is a Soldier
i have run across a set of dana 70 4;56 ring and pinion. the pinion is a 29 spline, guy says it fits a dana 70b,70u,or a 7070hd with a 5/8 pinion offset. my big question is will it work in a stock m715 rear differential? i have the 4;56's for the dana 60 front and have looked everywhere with no luck for the rears. any help would be appreciated . i am kind of lacking when it comes to knowledge on the differentials. thanks ,larry
Old May 21st, 2004, 10:32 AM
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
Call Randy ring and pinion...tell them you you have an M715.....tell them what you want.....gears....lockers....etc....they can set you up with 4.56 gears for the M715 Dana 70.....
HTML code is On
Dana 70 gears xownzux Modified Tech 9 May 26th, 2011 04:05 AM
M715 Dana 60 and normal Dana 60 ? 93-12smoke Modified Tech 24 November 6th, 2009 05:26 PM
4.56 gears w/230? boghog Modified Tech 12 November 5th, 2009 04:27 PM
Dana 70 35 spline spider gears Mikel Open Discussion 11 May 7th, 2009 02:41 AM
