Go Back   M715 Zone > General Tech > Stock Tech > Stock Tech Archives
Stock Tech Archives Look here first for all archived messages
Old May 21st, 2004, 04:00 PM
Nuke_littlejohn Nuke_littlejohn is offline
New Recruit
Nuke_littlejohn is an Observer
Default What did I get myself into!!!!
When I purchased my M715 about two weeks ago I knew it was not running right. Well I went through the normal little things like Plugs,wires,new dist.,points,cond.,cap,rotor,adjusted carb,new pcv,new fuel filter, and no matter what I did "no good". Now I am a backyard mech. so I did have it in the back of my head to check the compression but I was hoping to catch the problem elswhere. You may have guessed I went and checked it and it doesnt look good #1 170 #2 160 #3 170 #4 0 #5 0 #6 175 ..... I was hoping not to have to rebuild a motor right now but it looks like the first leg to a rebuild. I am going to pull the head soon to see whats going on but if any of you guys have anyother ideas I would love to hear from you.....
It just seems like if I get a vehicle that looks like crap it run great but if it looks great it runs like crap!!!
Old May 21st, 2004, 04:06 PM
Nuke_mcinfantry Nuke_mcinfantry is offline
Nuke_mcinfantry is an Observer
head gasket, BUT MAYBE it could be valves. or cam
1967 M-715 (A1)
www.homepage.mac.com/ltalessi
Old May 21st, 2004, 04:09 PM
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
I'd pul the head...., them is ugly numbers.....unfortunately I would be quite concerned it may be dead....
One thing that I do, probably others do too, when I'm looking at something to buy it is to crank the motor and see if it cranks even....if it cranks:
rr--rr--rr--rr--rr--rr
then the compression is even between the cylinders....if it goes
rr--rr-rr-rr--rr--rr
then there is a compression problem.....it goes faster and slower on cylinders with more or less pressure due to the resistance differences...it also tends to go higher and lower in pitch as it picks up speed and slows....
Just a thought....
Old May 21st, 2004, 04:10 PM
New Recruit
Is the civvy head gasket the same? Valves? Cam?
Old May 21st, 2004, 04:16 PM
brute4c's Avatar
Grand Poobah
All that is the same....only difference in the 2 is the head itself...chamber differences between different compression ratios and different bolt patterns on the front of them for different timing covers....gaskets, rocker gear, cam deck, cam, bearings, etc. all the same.
  #6
Old May 21st, 2004, 04:22 PM
New Recruit
If I have to rebuild, are their any upgrades like better cam , pistons ect.?
  #7
Old May 21st, 2004, 04:38 PM
not that im aware of. cheapest parts kit i could find was 1500!
1967 M-715 (A1)
  #8
Old May 21st, 2004, 05:16 PM
New Recruit
Dude that hurt Are you talking american dollars :!: Man I miss my Deuce
  #9
Old May 21st, 2004, 05:28 PM
Mikel Mikel is offline
Sergeant
Mikel is a Soldier
Try blowing air into #4 cyl and see if it comes out of #5.
Can head gaskets still be found for these things?? AB Linn?
  #10
Old May 21st, 2004, 05:46 PM
Nuke_68bhs715 Nuke_68bhs715 is offline
New Recruit
Nuke_68bhs715 is an Observer
Kanter Auto Products (www.kanter.com) has the "standard" rebuild kit for $820, and the "deluxe" (adds valves and valve guides) for $1020. You can also buy the parts separately if you don't need the whole kit. Good Luck.
HTML code is On
