Go Back   M715 Zone > General Tech > Stock Tech > Stock Tech Archives
Stock Tech Archives Look here first for all archived messages
  #21
Old May 22nd, 2004, 03:59 PM
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
Pour just a little in and rev it up...repeat a few times....cleans the carbon and any other junk out.....
  #22
Old May 22nd, 2004, 04:16 PM
Mikel Mikel is offline
Sergeant
Mikel is a Soldier
Even stuck rings will give you some sort of compression.
  #23
Old May 22nd, 2004, 04:32 PM
Nuke_littlejohn Nuke_littlejohn is offline
New Recruit
Nuke_littlejohn is an Observer
Quote:
Originally Posted by JeepistDoug/IA
I think I got a head gasket from napa for around $100.
cAN'T REMEMBER WHERE, BUT i BOUGHT A PISTON FOR $30, SOME OTHERS WANTED $100 PER PISTON, SO SHOP AROUND.
cap locks...Grrrr
Felpro# HS8169 $15.24 + shipping www.rockauto.com. But I will check autozone they can order felpro gaskets. What is hydro lock?
  #24
Old May 22nd, 2004, 04:56 PM
dave's Avatar
dave dave is offline
Private 1st Class
dave is an Observer
sounds pretty bad but could be stuck valves but I suspect you have bad blown head gasket or a nice path between the two cylinders with either the head or block ate up. I hope im wrong. Dont put water down the engine unless its runnin and even then rev it up to about 2500 rpms and slowly trickle it down into the carb, not enough to kill it or hydro lock it, just to clean carbon off of pistons and only aftrer its warmed up do you do it. if you put air into the cylinders to check for valve leaks, ect, make sure you have the valves in the normal closed position and add alittle to start with just in case the piston is at top of cyl. it will push the piston down usually.
hydro lock is when you fill the cylinder with fluid and the piston cant compress fluids so it forces the piston to hydraulicly lock up, it cant move and will even break pistons, rods, cranks, ect.
let us know what you find out. good luck
67 M725, 67 M715, 68 M715
  #25
Old May 22nd, 2004, 05:01 PM
New Recruit
Earlier I poured marvel mystery oil in all the cyl. to let them soak over night. Should I make sure it is all out of them before starting??? This hydrolock thing sounds really really BAD. I dont need anymore work.....
  #26
Old May 22nd, 2004, 05:25 PM
dave's Avatar
Private 1st Class
dave is an Observer
you probably didnt pour enough down the engine to cause it but just to be safe pull your plugs and then you can crank it with the starter and it'll blow any fluid out safely and wont cause any damage, then put your plugs back in and you will be fine. Dave
the pistons can compress air but not fluids so something has to give and the weakest link goes first, usually.
  #27
Old May 23rd, 2004, 09:00 AM
New Recruit
cap locks...Grrrr
OOPS I messed up this PN. is for the 232 don't get this one......
  #28
Old May 24th, 2004, 01:21 PM
New Recruit
I called napa today and one of the guys said he can order the head gasket for $24.95 plus shipping. :!: I will get a part number and post it. Turns out it might be stuck valves after all!!! I am going to pull the head and send it out for a valve job just as soon as I get all the parts. I'm going to drive it if it kills or breaks me
  #29
Old May 24th, 2004, 01:48 PM
Doug's Avatar
Doug Doug is offline
Das Fire Führer!
Doug is a Soldier
Sorry guys, That might have been for the kit now that I think of it, but it was not a complete kit. Think you had to order the valve cover seperate.
When I was born, God asked me if I wanted a long memory, or a long.............. what were we talking about???????
  #30
Old May 24th, 2004, 02:58 PM
Nuke_Danarchy Nuke_Danarchy is offline
Nuke_Danarchy is an Observer
Doug-I was hoping that you just had the decimal point in the wrong place..............too much information!
1969 M715
HTML code is On
