Go Back   M715 Zone > General Tech > Stock Tech > Stock Tech Archives
Stock Tech Archives Look here first for all archived messages
Old May 25th, 2004, 03:30 PM
Private 1st Class
My Deuce trucks have a single rubber line going from the hard brake line at the frame down the the axle, then...at the axle, it T's to either side. Will I have a problem running my brake system like that or do I *need* to go with the two rubber lines down from the frame like the traditional way???
Big Blocks RULE!
Old May 25th, 2004, 03:32 PM
LuckyPabst's Avatar
LuckyPabst LuckyPabst is offline
Private 1st Class
LuckyPabst is a Soldier
Default Brake Line Routing Question!!
Why would you ever run two rubber lines to the axle? I've only ever seen the one rubber into a tee off to each wheel. Rearrear that is. Frontrear would be different.
Chris
Old May 25th, 2004, 06:18 PM
Private 1st Class
Thanks...I'M TALKING ABOUT THE FRONTREAR.
Big Blocks RULE!
HTML code is On
Brake line diameter?? DivingKaiser Modified Tech 1 April 6th, 2010 04:23 AM
fisherman : Brake line pressure switch for brake lights. fisherman PseudoZone - Open Archive 12 November 11th, 2009 09:33 PM
fisherman : Brake line routing. fisherman PseudoZone - Open Archive 1 November 11th, 2009 03:02 AM
Brake Line Tools Tomahawk715 Modified Tech 10 November 1st, 2009 09:01 PM
Brake Line Problem? fisherman Modified Tech 14 October 2nd, 2007 07:13 AM
