Old May 25th, 2004, 06:37 PM
Private 1st Class
For anyone that's done shackle reversal and springover, how much longer did you go with the rubber flex line going from the frame to the axle (rear) or the frame to the spindles?
Big Blocks RULE!
Old May 25th, 2004, 08:01 PM
bggrntrk bggrntrk is offline
bggrntrk is a Soldier
haven't done one on a m715 but i lifted a 74 chev 6 inches and got longer rubber lines from Springfield Brake Co. in Springfield Mo. 1-800-333-2725 or 417-862-9233, hope that helps. they can make lines. larry
Old May 25th, 2004, 08:20 PM
Private 1st Class
Thanks Larry...I'll check them out tomorrow! I've been digging into it more too this evening and found one of the 4x4 rags had an add for a place and I went to their site. They had Earls and Russel stuff but nothing was in stock. I checked Summit and they have different models and lengths in stock.
Big Blocks RULE!
Old May 25th, 2004, 08:50 PM
Doug's Avatar
Doug Doug is offline
Das Fire Führer!
Doug is a Soldier
I thought about just hooking two together, with a bungee in the middle to keep it out of the way and also allow it to flex if needed. No spring over, just planning for more flex in the future.
HTML code is On
brake lines henry715 Open Discussion 2 March 6th, 2010 02:14 PM
Brake Flex-lines fng Modified Tech 5 February 28th, 2009 04:15 PM
rear rubber brake line lee brown Open Discussion 3 January 26th, 2009 06:45 AM
Why are the rear brake lines 1/4 inch? vacca rabite Open Discussion 16 September 8th, 2008 09:04 AM
Rubber (or flex) brake lines? vacca rabite Modified Tech 9 June 6th, 2008 08:41 AM
