Old December 24th, 2006, 01:20 PM
Archiver Archiver is offline
Moderator
Archiver is a Soldier
Default Radiator questions
radiator questionsTechnical Forums » Open Discussion Archives » radiator questions
http://m715zone.proboards102.com/index.cgi?board=openarchive&action=display&thread=1162860964
radiator questions
Post by stanman on Nov 6, 2006, 7:56pm
Would a radiator from the same year of J truck or wagoneer fit in a M715?
Re: radiator questions
Post by mgmorrison on Nov 6, 2006, 10:17pm
Move the passenger side support over. I think the outlets are at different corners also...
Post by brute4c on Nov 6, 2006, 10:20pm
The civvy Jees did not us the same radiator...the civvy 230s were 2 core instead of 3 and arent enough to keep it cool....I know from experience....and the other engine radiators have incorrect hose locations...
Post by stanman on Nov 6, 2006, 10:27pm
What about the earlier Jeeps with the tire smokeing 230? Wouldnt it be the same?
Post by mgmorrison on Nov 6, 2006, 10:34pm
That's what Jon was referring to...what happened to yours? A good radiator shop should be able to fix it.
Post by stanman on Nov 6, 2006, 10:38pm
Oh. Big ol' crack in the top tank and I think a few small leaks on the bottom tank.
Post by Barrman on Nov 7, 2006, 9:22am
Now that you know you really need a M715 radiator for the M715 with the 230. What engine do you have?
A 1967 396 Chevelle radiator will basically fit right in if you have a Chevy V8 in the truck. Change the angle on the hoses and it will work with the 230 as well. You can find them online for $150-$200. The biggest Summit aluminum radiator with the Chevy outlets will also work with the passenger side core support moved a few inches.
Post by stanman on Nov 7, 2006, 11:13pm
I still have the 230
Post by brute4c on Nov 8, 2006, 10:14am
I was able to modify a Modine 583 to fit...th is a CJ and A?MC car radiator, 3 core, has virtually the same face area...very very close...
After buying the radiator for around $160, I had to have a little work done...
Upper and lower hose mounts moved from one side to the other
Petthingy had to be moved due to interference
Mounting straps from the original radiator were removed and put in place of the ones on the new one.
New holes needed to be drilled in the staps to mount the radiator.
This unit does have an auto trans cooler...I just didnt use it...
The width, length and height work fine...though it is slightly taller than the stock one...
That stuff ended up costing $75 and so the bill came to $225...
I would go with the Summit model today...
Post by Hetzer on Nov 8, 2006, 9:42pm
I have a stock one that's been gone re-cored that I no longer need.
HTML code is On
stanman : radiator questions PseudoZone PseudoZone - Open Archive 9 November 12th, 2009 02:26 AM
radiator questions mojomot Modified Tech 7 May 19th, 2007 09:58 PM
radiator Treepusher Modified Tech 1 February 1st, 2007 05:35 AM
