Old December 24th, 2006, 01:29 PM
Archiver Archiver is offline
Moderator
Archiver is a Soldier
Default Hand Throttle?
Hand Throttle?Technical Forums Open Discussion Archives Hand Throttle?
http://m715zone.proboards102.com/index.cgi?board=openarchive&action=display&thread=1162874514
Hand Throttle?
Post by vrod02 on Nov 6, 2006, 11:41pm
Had a locking hand throttle on the M38. The 7 has to have this mod as well. Anybody done this? Its great for trail rides and warm up on cold days. It was the t handle that clicked to lock and turn to release.No sudden jerks to spill bev. of choice! ;D
Re: Hand Throttle?
Post by kwai on Nov 7, 2006, 12:21am
Some 715's have the option. The t-handle connects to the accel pedal with a piece of chain.
Re: Hand Throttle?
Post by jeepistdougiowa on Nov 7, 2006, 12:50am
If you live near a deuce bone yard you could probably mod one of them to do the job.
Another option, there's a guy I've wheeled around who uses a ten speed gear shifter (yes, from a bicycle) He used the handlebar clamp to mount it on his shifter...looks like it works pretty slick.
Re: Hand Throttle?
Post by gwen on Nov 7, 2006, 4:25am
That's what I did (the bicycle shifter route). It works great and I actually use it more than I ever thought I would.
[imghttp://img84.imageshack.us/img84/9601/m71573cm5.jpg[/img]
Re: Hand Throttle?
Post by gwen on Nov 7, 2006, 4:26am
why didn't that work... lets try again.
[image]
Re: Hand Throttle?
Post by gwen on Nov 7, 2006, 4:27am
oh, I forgot a bracket
Re: Hand Throttle?
Post by Barrman on Nov 7, 2006, 9:27am
DP had an aircraft style hand throttle at the National FE a few months ago. He said he got it from NAPA. I really liked it.
Re: Hand Throttle?
Post by tacomainUT on Nov 7, 2006, 10:49am
I'll be using a brake lever off a mountain bike.
Re: Hand Throttle?
Post by brute4c on Nov 7, 2006, 12:06pm
I'll try to remember to take a pic of mine tonight....factoy hand throttle...works on a cable from the dash to the accelator pedal "triangle" under the dash...
Re: Hand Throttle?
Post by SOCAL on Nov 7, 2006, 3:04pm
Yep, bike shifter cable.. in my XJ
[image]
Re: Hand Throttle?
Post by BinfordM715 on Nov 7, 2006, 6:45pm
Did the same on my CJ. Final connection to the carburetor linkage was done using a few inches of pull-chain (such that you'd have on your attic light) so I could hit the floor pedal to goose it and the chain would go limp. Still had to remember to pull the lever to get it to slow down though! It was just used for those slow, bouncy crawls over roots, rocks, etc., where it was hard to hold your foot still on the gas pedal. Total cost was something just over a dollar for a new cable. The rest was all junk-yard stuff.
Re: Hand Throttle?
Post by SOCAL on Nov 7, 2006, 6:50pm
Looop, Pin and washer kept mine in place..
[image]
Re: Hand Throttle?
Post by vrod02 on Nov 7, 2006, 8:33pm
This is the one I want.Interesting post guys! I understand the shifter mount but I'll be in 1st gear all day! ;D
Re: Hand Throttle?
Post by amphi on Nov 7, 2006, 10:17pm
Some on eBay
eBay Item #110051840050
NOS AMC Rebel SST Ambassador Hand Throttle Cable Cruise
http://cgi.ebay.com/ebaymotors/NOS-AMC-Rebel-SST-Ambassador-Hand-Throttle-Cable-Cruise_W0QQcmdZViewItemQQcategoryZ341 98QQhashZitem110051840050QQihZ001QQitemZ1100518400 50QQrdZ1QQsspagenameZWDVW
eBay Item #150049591793
AMPHICAR HAND THROTTLE CABLE WITH METAL HANDLE
http://cgi.ebay.com/ebaymotors/AMPHICAR-HAND-THROTTLE-CABLE-WITH-METAL-HANDLE_W0QQcmdZViewItemQQcategoryZ34206QQhashZ item150049591793QQihZ005QQitemZ150049591793QQrdZ1
Re: Hand Throttle?
Post by porkchop on Nov 8, 2006, 8:48am
I bought a locking one at napa a few years ago that I used for the shift cable on my quadratrac t-case. I used it instead of vacum power. It was not to much from what I can remember.
Re: Hand Throttle?
Post by brute4c on Nov 8, 2006, 9:52am
Sorry...with a bunch of stuff after work yesterday, I forgot to snap a pic...will do tonight!!
Re: Hand Throttle?
Post by jfnemt1ff1 on Nov 8, 2006, 1:17pm
[image]
Re: Hand Throttle?
Post by jfnemt1ff1 on Nov 8, 2006, 1:21pm
<*img src="http://img72.imageshack.us/img72/617/m715002bm8.jpg" alt="[image] " border="0"/>
Here is the set up in my 725
Re: Hand Throttle?
Post by brute4c on Nov 8, 2006, 9:53pm
Heres a few shots of mine:
A little to the left of straight on:
[image]
You can see the cable coming from the dash on the upper left back the the pin with the phillips screw right behind it...that is the setup...easy really to do....
Straight on:
[image]
The pin goes through the linkage arm and has a cotter pin to keep it from backing out...then the cable goes through the hole down the other end of the pin...the screw goes into a block that the cable passes through and is used to adjust the tension.
From the passenger side:
<*img src="http://www.m715zone.com/jonmisc/hand_throttle3.jpg" alt="[image] " border="0"/>
You ca see the mounting pin at the back and also the U shaped piece that goes on the pin and around the arm to mount the throttle cable to the carb.
Knob on dash:
<*img src="http://www.m715zone.com/jonmisc/hand_throttle4.jpg" alt="[image] " border="0"/>
Re: Hand Throttle?
Post by vrod02 on Nov 8, 2006, 9:56pm
works for me! Thanks brutis!
Re: Hand Throttle?
Post by brute4c on Nov 8, 2006, 10:21pm
No sweat!
HTML code is On
vrod02 : Hand Throttle? vrod02 PseudoZone - Open Archive 17 November 12th, 2009 02:28 AM
binfordm715 : Hand throttle cable installation query Binford PseudoZone - Open Archive 6 November 11th, 2009 09:26 PM
Hand Throttle? halftrack78 Open Discussion 14 August 11th, 2009 07:19 AM
Need a hand gimpyrobb Open Discussion 0 February 19th, 2008 05:07 AM
