Old December 24th, 2006, 01:39 PM
Archiver Archiver is offline
Moderator
Archiver is a Soldier
Default Spring Bushing OD
Back...spring bushing O.D.Technical Forums » Open Discussion Archives » Back...spring bushing O.D.
http://m715zone.proboards102.com/index.cgi?board=openarchive&action=display&thread=1162782968
Post by m715jeep25 on Nov 5, 2006, 10:16pm
Hello all. I'm back after several years of just checking in every 6 months on the zone. My ride is posted in the members section under Roger M715 on Rockwells w/ 500 Cadillac engine.
Any ways I've started working on the truck again. Finally got back into a place where I could work on it and spend a little extra money.
Question: What is the inside diamter of the rear leaf springs (front & rear mounting locations of the rear spring)? Or I'll ask the same question in a different way...what is the O.D. of the spring bushing?
I'm adding rear steering and need to mount the springs under the chasis and change out the spring bushings so I can use a 9/16" bolt.
Thanks,
Roger
Re: Back...spring bushing O.D.
Post by brute4c on Nov 6, 2006, 10:35am
Hi Roger!!!! Great to hear from you!!
If no one else gets this info posted, I have a set of NOS springs at home and will measure then...
Post by m715jeep25 on Nov 6, 2006, 12:57pm
That would be great! I wanted to get the parts on order so I can tear things down and start on it this weekend. While you're looking at the springs could you check if the front and rear bushings of the "rear" leaf springs are the the same O.D. and if you have a NOS front spring pack I'll take those bushing O.D.'s as well....I might as well change them all while I'm at it.
Brute4c I think we met at one of the FE in Manhatton in 98-00. Time flies...and it all runs together.
thanks,
Roger
Post by brute4c on Nov 6, 2006, 1:08pm
We sure did Roger...it hs been a while...my 9 year old daughter turned 4 while we were there....the National we had at Tutte Creek in 2001...great wheelin!
I'll get those measures for ya...no sweat!!
Post by brute4c on Nov 6, 2006, 10:17pm
OK...the front is different than the rear on the rear spring...
The bushing is "made" into the leaf...when I bought these, the metal sleeve is already in them...
I also have a spare frame and I checked the numbers versus the mounts on the frame...
Front eye of rear spring:
Bushing Id: .875 inch
Mount on frame OD: .875 inch
Width: 2.5 inch
Outside of bushing/inside of leaf spring eye: 1.090 inch
Bushing Id: 1.000 inch
Mount on frame OD: 1.000 inch
Width: 2.5 inch
Outside of bushing/inside of leaf spring eye: 1.225 inch
The OD of the bushing/ID of the spring eye is as close as I can get with it in their...it might be off slightly but I took great care to make sure I was at the edge and straight and measured several times...its gotta be pretty close...
One would have to press these pieces out and measure them to do better...
Post by m715jeep25 on Nov 7, 2006, 9:07am
This information was a great help! Thanks for taking time out of your day to help. It saved me lots of valuable fab time.
regards,
Roger ;D
Post by brute4c on Nov 7, 2006, 12:06pm
Best wishes on the project Roger, anytime I can help......pics are always welcome ya know!!!!
HTML code is On
m715jeep25 : Back...spring bushing O.D. PseudoZone PseudoZone - Open Archive 6 November 12th, 2009 02:22 AM
gimpyrobb : Steering shaft bushing ? gimpyrobb PseudoZone - Open Archive 4 November 10th, 2009 09:31 PM
core support body bushing ?? ryanroo Stock Tech 5 January 3rd, 2009 06:57 AM
Spring bushing the1968jeepthing Stock Tech 1 January 30th, 2008 01:51 PM
