Old December 24th, 2006, 01:39 PM
Archiver Archiver is offline
Moderator
Archiver is a Soldier
Default Vigilante 327
Vigilante 327 V8Technical Forums » Open Discussion Archives » Vigilante 327 V8
http://m715zone.proboards102.com/index.cgi?board=openarchive&action=display&thread=1162746071
Vigilante 327 V8
Post by stanman on Nov 5, 2006, 12:01pm
Has anyone ever swapped in a Vigilante 327 V8? Just wondering.
Re: Vigilante 327 V8
Post by porkchop on Nov 5, 2006, 6:56pm
Not worth it. I had one in a 67 wag. Lots of torq but finding parts for one is just as hard as the 230, if not harder.
Post by stanman on Nov 6, 2006, 1:47am
oh. just was wondering if it would be a viable swap
Post by fisherman on Nov 6, 2006, 1:52am
You could do it easy enough, as they came in full size trucks and wagoneers for a couple of years, its just an oddball. You might have a hard time finding parts, and pay a premium. Probably be better off going with something newer and easier to get parts for. Lots of other options. If I had one and it was known for sure to be a good engine I probably wouldn't have a problem putting it in. After all I'm going with a Buick 350.
Post by stanman on Nov 6, 2006, 8:09pm
Would the bellhousing pattern be the same?
Post by fisherman on Nov 6, 2006, 9:50pm
Good question, don't know.
Post by brute4c on Nov 6, 2006, 10:23pm
There is only 1 engine on Earth besides the 230 that shares the same bellhousing pattern...that is the older 226 flat head 6 cylinder.
Other than that NOTHING will bolt up without adapters.
Post by alqcca on Nov 6, 2006, 11:04pm
Have one in mine that the FD installed.
The bell housing I assume came with the engine and bolted to the T98
However a longer input shaft was needed fo the tranny.
they sold off the truck for that reason.
The only reason I like it it that it is the v8 that comes from the same year civilian truck.
Other than that parts are a pain!
When it goes I'll put the 360 from my CJ in it
Al
[image]
Post by stanman on Nov 7, 2006, 1:10am
I did a little research on the engine and AMC made 3 versions, the 250, 287 and 327 from 1956 to 1968. But Jeep had them only from 1965 to 1968. One would think that you could find parts but I guess not. Just for kicks and screams, how hard would it be to swap in one? would the motor mounts be similar or totaly differnt?
Post by porkchop on Nov 7, 2006, 7:22am
The motor mounts on a M715 look the same as the ones that were on the '67 wag I had. without having them side by side it is hard to say. But I am thinking it should drop right in.
HTML code is On
stanman : Vigilante 327 V8 PseudoZone PseudoZone - Open Archive 9 November 12th, 2009 02:21 AM
Vigilante? ronzello Open Discussion 13 December 2nd, 2007 01:31 PM
