Old December 24th, 2006, 01:44 PM
Archiver Archiver is offline
Moderator
Archiver is a Soldier
Default NAPA brake part numbers
NAPA brake part numbersTechnical Forums » Open Discussion Archives » NAPA brake part numbers
http://m715zone.proboards102.com/index.cgi?board=openarchive&action=display&thread=1162306030
Post by maddawg308 on Oct 31, 2006, 9:47am
Have a stock M725, need to get wheel cylinders for all wheels, along with show return springs and brake screw adjusters. Does anyone have the NAPA parts numbers for what I need to order tomorrow?
Re: NAPA brake part numbers
Post by brute4c on Oct 31, 2006, 12:03pm
Springs and adjusters, no....wheel cylinders:
If you want stock, you gota et NOS from the mlitary guys....
If you want to do a slight modification and want new parts with stainless steel pistons to elp with the corrosion problems inherent in this brake system get this part:
Tru torque W37262 and W37263, left and right.
The following are part numbers for one side, not sure which off hand
Bendix 33595
Raybestos WC37263
EIS EW73615
Wagner F73615
They should be able to cross those numbers for ya if need be.
Post by brute4c on Oct 31, 2006, 12:06pm
By the way, the mod you need to do to put those wheel cyliders on is to open the mounting bolt holes in the backing plate about 1/4 inch or so straight down...so with a rat tail file or rotary file, just enlarge the hole so the bolt is a little bit lower than stock...poof...all else works perfet including the brake line fitting.
Post by stanman on Nov 2, 2006, 8:49pm
What about the shoes?
Post by brute4c on Nov 3, 2006, 9:57am
Mil surplus...they get a chunk for them...plus core charge...
HTML code is On
New NAPA part Numbers - Master Swap rboltz Modified Tech 11 September 13th, 2010 05:57 PM
Brake Part Numbers clearingcrap Stock Tech 6 June 8th, 2009 07:37 AM
NAPA part numbers for front and rear wheel bearings? maddawg308 Open Discussion 13 January 5th, 2008 08:33 AM
NAPA part number for brake shoe return spring? maddawg308 Stock Tech 5 April 15th, 2007 05:58 PM
NAPA brake part numbers Archiver Open Discussion Archives 0 November 3rd, 2006 07:11 PM
