Old December 24th, 2006, 01:48 PM
Archiver Archiver is offline
Moderator
Archiver is a Soldier
Default Tailgate hardware
Tailgate hardware?Technical Forums » Open Discussion Archives » Tailgate hardware?
http://m715zone.proboards102.com/index.cgi?board=openarchive&action=display&thread=1161756047
Tailgate hardware?
Post by dxeflyr on Oct 25, 2006, 2:00am
Finally got a tailgate this week. The problem is, the metal tabs normally welded to the back of the bed to secure the gate are missing on my truck. Are they available? Has anyone else had this problem?
Re: Tailgate hardware?
Post by 40grit on Oct 25, 2006, 2:14am
If I think I know what you are talking about, they bolt on the rear of the bed
Post by dxeflyr on Oct 25, 2006, 2:25am
I think they're welded; they were on the truck I pulled the gate from. They look like they were cut off of my truck.
Post by gimpyrobb on Oct 25, 2006, 8:49am
Why did you cut them off your truck?
Post by robertcowan on Oct 25, 2006, 9:01am
THERE BOLTED FROM THE FACTORY WITH 2 BOLTS EACH. CALL VINTAGE POWER WAGONS THEY GOT EM.
BOB
Post by brute4c on Oct 25, 2006, 10:02am
They are listed on the VPW price list as follows:
Tailgate hinge, upper $24.00 ea
Tailgate hinge, lower $24.00ea
Tailgate hinge pin $10.00 ea
Post by bluesman2a on Oct 25, 2006, 10:26am
Dang!!! For $58, you can bet your sweet bottom I can make some REALLY serious replacement hinges...
Just go buy a length of .75" OD DOM tube .120 wall. Cut it and use a 1/2 bolt. weld it and call her good... Total cost about $5 each and some time with a welder.
Post by Barrman on Oct 25, 2006, 10:53am
Guys, I think Bill needed the latch plate at the top of the gate to hold the chains and keep the tail gate up.
Bill,
My tail gate latches were welded on and then ground off by the fire department. I just happen to have a completely stock truck in my class right now with the stock tail gate. The latches are welded on this one too. I do not know of a source for them off hand. They look like they would be made from some angle iron easily enough though. I don't have a camera here right now, but might Thursday. If you need pictures and measurements, let me know.
Herb,
Here is a shot of the hinges I made for my custom tailgate last year. I used the stock hinges dimensions, so the bottom half should be the same as a stock one. Just thicker.
[image]
Post by kwai on Oct 25, 2006, 11:17am
The tabs used to latch the tailgate are welded on. Look to be about 3/8 steel.
Post by dxeflyr on Oct 25, 2006, 11:37am
Tim: that's exactly what I meant. I spent 12 hours driving to LA yesterday and my mind was a little fuzzy when I got in. If you could take some pics, I would certainly appreciate it. I'll whip some new latches up down at the hangar.
Post by kwai on Oct 25, 2006, 11:45am
Tim, How are those bumperettes working out for you? Looks like you got them mounted.
Post by seanjames on Oct 25, 2006, 11:51am
I think he means the braket at the top of the bed were the chain is connected and the tail gate is secured in the upright position.
it can be seen in this picture, though not the best angle
[image]
Sean
Post by dxeflyr on Oct 25, 2006, 11:53am
Sean: that's what I meant, although your pic is showing the little red "x".
Post by seanjames on Oct 25, 2006, 11:55am
I was having trouble getting the pic the way I wanted, let me know if it works now.
Oh and if you click on the picture once and then again after it loads you will get the high res version. Well at least that is how it is supposed to work.
Post by dxeflyr on Oct 25, 2006, 11:59am
Pic working now. Yep, the upper latch that secures the gate closed and holds the chain.
Post by bluesman2a on Oct 25, 2006, 12:40pm
Oct 25, 2006, 10:53am, Barrman wrote:
Herb,
[image]
Now THAT's what I'm talkin' 'bout Willis... for the kind of $'s they want for a replacement, I'd just as soon spend a little time and get something better (i.e. now you can take the tailgate off very easily with just a couple bolts!
Post by Barrman on Oct 25, 2006, 12:49pm
A few things still have to fall into place for me to get the camera to my room, but Thursday is still looking good for that.
Steve, the bumperettes and shackles really set the truck off, thanks again. I came back from the ranch with 4 bumperettes. I don't remember who I got which ones from. I just know that two are on the truck and two are in my room getting cleaned up still. I have a guy at work bringing me a 7" channel length tomorrow. Then I just need to cut the shackle slots in it to complete the front and back ends.
Post by BinfordM715 on Oct 26, 2006, 12:32am
Here ya go, Bill. I think this is what you're after:
[image]
[image]
[image]
That's on the passenger side. Driver's side is a mirror image, as you probably guessed! <img src=" border="0"/>
Post by over2land on Oct 26, 2006, 2:50am
Nice night time pics Timmah!
Once again, as much as I think my truck was trashed when I got it...
little things like this make me happy with my lucky choice.
Post by Barrman on Oct 26, 2006, 9:26am
Here are the measurements to go along with the pictures.
1-3/4" side to side x 2-1/2"
The tab below his quarter is 1-1/4" from the bed to the end of it. The chain hole is 1/2" diameter in the middle of it.
The angle on the top of the hook side starts 2-3/8" from the bottom. (I measured from where the bottom would be if the little 3/8" on each side notch hadn't been there.)
The slot for the hook is just a hair over 1". Just make it exactly the same as the slot in your tailgate. Matter of fact, you should make it from the tailgate slot so it lines up right anyway.
Post by dxeflyr on Oct 26, 2006, 6:51pm
Thanks a lot for your efforts, Tim! I really appreciate it. I will go down to the hangar and get a couple of these cranked out next week. Thanks again!
Post by grantshire on Oct 29, 2006, 8:35pm
Care to make an
extra set? I have the same issue; the fire department that modified mine cut them off my bed as well (also hung about 500 pounds of standing boardsoff the back as well).
We have cleaned up all the FD add-ons and it looks like a M715 again. I have one of Bob's heavy duty tailgates but I only have weld remnants where the latch hardware used to be.
Post by dxeflyr on Oct 29, 2006, 9:54pm
I will see what I can do next week when I get back to working on trucks. This week we are putting an annual inspection on a T-6 Texan (airplane) and it looks as if a lot of the serviceable/replacement items are original 1941 vintage, haha. I am up to my ears in really, really old grease.
HTML code is On
dxeflyr : Tailgate hardware? PseudoZone PseudoZone - Open Archive 4 November 12th, 2009 02:01 AM
