  #11
Old September 3rd, 2019, 01:21 PM
kwai's Avatar
kwai kwai is offline
Sergeant
kwai is a Soldier
No. Hella makes a 100 amp switch. It also has a key.
http://hellahd.com/index.php/default...cs-product-11/
  #12
Old September 3rd, 2019, 01:56 PM
ColoradoSpringsRob's Avatar
ColoradoSpringsRob ColoradoSpringsRob is offline
ColoradoSpringsRob is a Soldier
For convenience, $12, Amazon.
Mixed reviews...
  #13
Old September 4th, 2019, 06:47 PM
grymsr's Avatar
grymsr grymsr is offline
grymsr is a Soldier
looks good. thanks for the tip
  #14
Old September 4th, 2019, 06:53 PM
grymsr's Avatar
grymsr is a Soldier
Quote:
Originally Posted by ColoradoSpringsRob View Post
it looks like the lowest reviews seem to have a common complaint: switch failure. from the photos one reviewer posted, it appears that the switch housing was not water tight allowing corrosion. what his application was he didn't give many details to, but it would seem that extra sealing might correct the issue.
also, many low reviews mention that the key fell out. I thought that was how it was designed. losing the key seems more carelessness than a manufacturer's issue.
all said and done, I think I'll give it a try. Thanks for the lead.
  #15
Old September 5th, 2019, 08:27 AM
kwai's Avatar
Sergeant
kwai is a Soldier
This is the switch I use on my CJ. It has a rough life but has never failed. Heavier duty than the Hella switch.
https://www.delcity.net/store/Master..._4877.h_169694
  #16
Old September 5th, 2019, 02:47 PM
grymsr's Avatar
grymsr is a Soldier
kinda pricey but what isn't in the M715 world.
  #17
Old September 6th, 2019, 08:18 AM
grymsr's Avatar
grymsr is a Soldier
well, it turns out both batteries were dead. Battery Tender would not charge so I put a HF charger on them. One battery has recovered (I hope) so now charging the second. We shall see.
  #18
Old September 6th, 2019, 08:36 AM
grymsr's Avatar
grymsr is a Soldier
AAAARRRRGGGGHHHH!!!!
both batteries are toast. now I have to go replace them.
any suggestions on what I should get?
  #19
Old September 6th, 2019, 10:56 AM
kwai's Avatar
Sergeant
kwai is a Soldier
I like the napa AGM batteries. Don't leak all over the place. Also, NAPA sells them at 30% discount on the 2nd saturday morning of the month around here. So the price is good.
Get your alternator checked. It's probably what killed the batteries.
  #20
Old September 6th, 2019, 02:32 PM
Don Cavey's Avatar
Staff Sergeant
Don Cavey is a Soldier
I suspect the same. I disconnect the link between the batteries everytime I shut down the truck. No chance to drain the batteries.
One day, I will have to get off of my fat arse and install the other alternator that I have. I suspect it is a good one. Arrrggghhh.
