Results 1 to 7 of 7
Thread: Lights and tires
    Oct 2019
    Rock Valley Iowa Sioux County
    Default Lights and tires
    is there any different light I can put in my truck that is easy to install or would I have to rewire everything to do so? is there any tire that is kind cheap and the original military tires and the wheel sizes is 9.00-16.
    its still on a 24v system just was wonder if you could put new style headlights and stuff without rewiring the whole thing
    Jun 2014
    Eastern Maine
    Are you looking for something brighter or just a replacement, and is your truck still 24v ? I don't believe 9.00x16 and cheap is going to happen unless you get lucky and find some used ones that are not dry rotted. A lot of the new tires that are cheaper are not DOT approved for on road use. I purchased 4 new Firestone NDT's last year and with free shipping they still were $325 each.
    I believe I might have seen some LED headlights at Summit that would operate on 24V. Had turn signal lights built into the bottom portion of the light, too.
    Look up cooper tire. I run the sta super lug works great
    I bought a pair of these Autopal headlight conversions, but have not installed them yet. You can specify 12v or 24v.
    Years back I installed hella halogen lights that are PLENTY bright and come in 24 volt...
    Hella number for 24 Volt H4 headlight bulb: 64196 (that was 2 decades ago...)
    Since that was originally posted, it appears to be renumbered as 78160 in a Hella bulb...same specs in every regard including 24 volt and 70w low beam/75 watt high beam...crossreferences listed below:
    EIKO 01010
    GE 50450
    LUCAS 475478
    NARVA 48892
    OSRAM/SYLVANIA 64196
    PHILLIPS 13342
    WAGNER 2475H4
    Fits in a housing that fits the stock M715 headlight location...housing is number:
    79562
    Amazon lists the housing here:
    https://www.amazon.com/Hella-0023950.../dp/B005OULUQO
    About $35 each housing and 6 bucks a bulb...
    As far as brightness, they are outstanding...I never even thought more light would be needed...great coverage on low, absolutely lights up the whole world in front of you on high!
    Oh and easy to install...they fit right in the M715...you just need to get the wires cut off the originals and onto these...any H4 bulb socket with 3 wires will let you do it...
