Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 49
Thread: Wheel Cylinder Conversion
  1. #21
    Quote Originally Posted by das beef View Post
    heh to bad im breaking brake lines left and right
    I think it bears mentioning here, that while replacing the wheel cylinders, ALL of the steel and rubber lines should be replaced too. If the inside of the wheel cylinders look anything like all the ones I've replaced on various M715's then the lines and hoses probably do too, and many of them are still running around on their factory bits.
  2. #22
    Too true!
  3. #23
    Oct 2009
    charlottesville VA
    heh i'll be honest my old wheel cylinders did'nt look bad at all really ... i just figure id replace them to try to get all my parts to new lol and yes i figured the a brake line or two would break ... i replaced one side already and im also going to finish the other side
  4. #24
    Paron, Arkansas
    Chicklin's post about the Napa #9025 and 9026 cylinders not fitting the stock rubber brake lines is correct. Use Napa flex-hose part #36791 for the fronts, and Napa part #36801 for the rear. You will need two reducer fittings at the rear tee, and grind a little part of the fitting to go through the holder tabs, but that way you can replace all the flex-hoses with Napa parts. I finished-up the brakes on my short-truck. All new master cylinder, wheel cylinders, flex-lines and all new steel lines from Napa parts.
  5. #25
    Cool brake job
    this is my first m715 i love it and hadnt driven it yet but i will as soon as it will stop.thanks good job.
  6. #26
    New brake cylinders or any replacement is not neccessary. Rebuilt the old ones, hone them, use new rubber parts. You will get them under the number Dorman First Stop 3609, will replace Coniseal WK3609, Raybestos WK20, Wagner WK3609 (the original replacement) and Bendix 66821).
    Hope this helps.
    Wolf
    P.S. Have a new set of repair kits just ready to install. New means got it last month factory fresh.
  7. #27
    Mar 2012
    truckee california
    Anyone using napa TS 451 brake pads as a replacement to the stock units? The prices are much nicer and are a direct fit.
  8. #28
    This looks to be an excellent conversion, sadly none oof the parts mentioned are available in the UK and I can't find a supplier that posts internationally!
    Would these fit?
    http://www.ebay.com/itm/Rear-Brake-W...#ht_319wt_1018
  9. #29
    Quote Originally Posted by lightweight View Post
    Would these fit?
    Those are the correct wheel cylinders.
    Have you tried rockauto.com ? I'd bet they might ship overseas.
  10. #30
    Quote Originally Posted by randyscycle View Post
    You were spot on there - they do ship internationally and I've ordered the parts!
    Many, many thanks.
  1. Master Cylinder Conversion - Upgrade
    By Warthog in forum Modified Tech
    Last Post: April 6th, 2021, 09:21 PM
  2. Wheel cylinder ?
    By 93-12smoke in forum Modified Tech
    Last Post: December 1st, 2009, 01:31 AM
  3. stock wheel cylinder
    By Chef in forum Stock Tech
    Last Post: September 30th, 2008, 09:54 AM
  4. Wheel cylinders to Vette master cylinder Q's
    By Nuke_Bill in forum Modified Tech Archives
    Last Post: March 31st, 2004, 10:48 PM
