  #31
Old March 9th, 2013, 09:41 PM
randyscycle's Avatar
randyscycle randyscycle is offline
Staff Sergeant
Location: Rhoadesville, Virginia (five miles from no place)
randyscycle is a Soldier
I love Rock Auto. Unfortunately my checkbook doesn't!
"Free advice is worth what you pay for it."
  #32
Old March 10th, 2013, 04:24 AM
Flingarrows's Avatar
Flingarrows Flingarrows is offline
Sergeant
Flingarrows is a Soldier
Quote:
Rock Auto loves me too, they get a fair chunk of my hobby budget
Thanks, George
Joshua 24:15
  #33
Old June 10th, 2013, 10:42 AM
Pen1311's Avatar
Pen1311 Pen1311 is offline
New Recruit
Pen1311 is a Soldier
I know it has been awhile since you posted this. Just wanted to say thanks for the post and the great pics.
Mike Brink
  #34
Old August 27th, 2013, 09:53 AM
gene imes gene imes is offline
Civilian
gene imes is a Soldier
Another possibility for remove the three screws is to drill the heads completely off and pull the drum. This gives good access for WD40 and vise grips. good thread. thanks
  #35
Old September 30th, 2013, 06:33 AM
Jim Hunter's Avatar
Jim Hunter Jim Hunter is offline
Jim Hunter is a Soldier
I use an impact screwdriver...That works best for me...
Jim
  #36
Old June 25th, 2016, 09:12 AM
Nailhead's Avatar
Nailhead Nailhead is offline
Corporal
Nailhead is a Soldier
We installed the E-350 wheel cylinders in my truck, along with the '74 Corvette MC, and it appears to work great, with a rock-solid pedal at half travel. It has only been driven about 30', so the jury is still out on stopping power.
One thing we learned in the process of modifying the WC mounting holes is that half a chainsaw file chucked into a drill works really well.
Thank you very much to all those who had a hand in coming up with this modification.
  #37
Old June 11th, 2017, 05:33 AM
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
It has now been found that there are Chevy wheel cylinders that fit the backing plate with no mods at all and connect to the stock brake lines.
Raybestos numbers for the cylinders are:
Left-WC9344
Right-WC9345
Heres a pic of one in the backing plate:
THANKS to Kaiserman for figuring this out and posting the part numbers and pic!!
  #38
Old June 11th, 2017, 08:58 AM
brycer1968's Avatar
brycer1968 brycer1968 is offline
Private 1st Class
brycer1968 is a Soldier
Default 1.25" bore tho . . .
Ive been following this in the other thread and I was all excited about this opportunity. I did a quick parts search on line and those part numbers correspond with a 1.25" bore cylinder - so they are bigger than the stock 1-1/16" bore of our stock WC's. Any thoughts on how much that changes the usability of this wheel cylinder in mostly stock or even in modified braking systems??
Left-WC9344
Right-WC9345
Bryce
1969 M725 ambulance
  #39
Old June 13th, 2017, 04:48 PM
gerrykan's Avatar
gerrykan gerrykan is offline
gerrykan is a Soldier
brycer1968,
It has been a couple of decades since I took a hydraulics course, and my memory isn't as good as it once was, but...
I think when the wheel/slave cylinder is larger diameter than the master cylinder it will be easier to push the master cylinder.
This is because the pressure from the master cylinder is spread out over the larger piston diameter of the wheel cylinder.
The master cylinder will have to travel further to accomplish this, so there is the possibility of running out of stroke in the chosen master cylinder.
If you go in reverse with a large diameter master cylinder and small diameter wheel cylinders, the stroke will be short, but may require a lot of pedal pressure to actuate the wheel cylinders.
Please research this before taking my word as gospel, because I could be remembering wrong.
If anyone knows that I am wrong, please speak up and I will have a moderator remove my post so as not to disseminate false information.
Roy
  #40
Old June 13th, 2017, 04:58 PM
gerrykan's Avatar
Another reference would be a bottle jack, or floor jack.
The pump piston is usually much smaller diameter than the lifting piston.
The small piston pump will lift a great deal of weight with little effort, but you have to apply quite a few strokes to accomplish the lift.
Roy
Master Cylinder Conversion - Upgrade Warthog Modified Tech 43 September 26th, 2020 09:35 PM
Wheel cylinder ? 93-12smoke Modified Tech 1 November 30th, 2009 09:31 PM
stock wheel cylinder Chef Stock Tech 2 September 30th, 2008 06:54 AM
Wheel cylinders to Vette master cylinder Q's Nuke_Bill Modified Tech Archives 10 March 31st, 2004 06:48 PM
