Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: lift kits/suspension lifts
  1. #11
    Northern Colorado
    Unless you're in a suburb or city in Iowa, you should have no problem getting your split rims serviced. Any farm place that does tires or big rig outfit should have the safety case required to service your wheels. For custom wheels, I've seen actual prices starting aorund $200 range. That is PER wheel. And most of them are a flat center disc. I like the big truck look. <g> IIRC, you wanted "attitude", right!?
  2. #12
    Default '69 M715 parts in Massachusetts
    Bluetorch fabworks made me centers for $60. cut the centers out of a wagon wheel with a plasma and welded the two together $147 total and you can have designs in them too. I made some directional holes kinda like a weld typhoon. pretty cool looking for the old work horse and they make the 44's look nice!!!
  3. #13
    could they be sent in and made into bead lockers though
    -brad
    '86 & '98 Ram 4x4's
  4. #14
    Yes. use rockstomper weld on rings. this months 4whl and off road.
  5. #15
    Oh yea I almost forgot. I'm not too sure why but when I did the spring over I did the shackle reversal and made some costom perches out of 2.5" square tube. with that combination up front and 4.5" blocks out back (shackle flip also). the front is only 1.5" lower than the back. I plan to remedy this by putting 3" blocks in the back to lower it a little cause I know the bumper will bring it down more. havent driven it yet but hope too soon.
  6. #16
    i have searched the net for lifts and spring over information and found a web site called mesa4x4.com and they are going to have a spring-over conversion kit for sale soon. i think it was in"tech info"
    M715,s..are a mans jeep...
  7. #17
    i have searched the net and found a web site called mesa4x4.com and they will have a spring over conversion soon. i think it in tech info
  8. #18
    Stockton Wheels in Stockton, California makes one piece wheels that will work. They will build them to your specs (Wheel Diameter, Wheel Width, and whatever offset you want). Around $200.00 per wheel. Their website is www.stocktonwheel.com
  9. #19
    i went to my local less schwabb (dont know if i spelt it right), and they can get me custom rims made for a round $150.00 per wheel. if you live neer one you should ask them.
  10. #20
    Mar 2004
    northern Arizona
    Quote Originally Posted by SCkaiser67
    Got pics of them thar fancy-pants wheels?
    Rich
  1. Lift Kits
    By Rustybritt in forum Open Discussion
    Last Post: August 25th, 2009, 01:20 AM
  2. steering arm lifts/ spring over
    By talulah in forum Modified Tech
    Last Post: October 16th, 2008, 12:39 AM
  3. air bag suspension
    By dodmort in forum Open Discussion
    Last Post: January 26th, 2008, 09:50 AM
  4. ultimate lifts
    By davemooney1 in forum Modified Tech
    Last Post: August 20th, 2007, 05:48 PM
  5. Manufacturing M715 Lift Kits
    By BulletSponge in forum Modified Tech
    Last Post: April 13th, 2007, 12:00 AM
