Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 33
Thread: H.E.I. distributor from chevy to 230 6cyl
  1. #21
    Jun 2009
    Mt. Prospect, Illinois 60056
    Can't remember where I saw the new electronic guts that fit in the 230 ignitor. It seemed rather simple and neatly done. Cutting a few wires, and reconnecting them was the main issue. Most of it seemed to be a new electronic board that fits right in. Please correct me if I'm dreaming.
  2. #22
    I think your talking about a petronix kit.
  3. #23
    Jun 2009
    That must be it. Is their a big advantage to this? I haven't any trouble with starting or idle at all. Thought about changing it out, but why fix something that isn't broke.
  4. #24
    Does away with points and condenser. I have their kit on my ford 300 as it's one less thing to mess with ( it was about 50-60$ on sale which was cheaper than a new distributor setup). Supposed to provide more efficient spark.
  5. #25
    Default http://www.pertronix.com/default.aspx
    Here is their website:
    If you look in the catalog, you can find more information. Mine has a civilian distributor and they make a 12v kit for it. According to their literature, they can adapt to almost any distributor. There is a 24v kit for the military stock distributor, but I'm not sure yet about a 24v kit for my civilian distributor.
    Quadratec in PA can sell you the kit for a good price, but you have to get Tech Support from Pertronix.
    Hope this helps,
    Mike Cougler, MSgt, USAF Retired, '72-93
    '67 M725, VIN 10030, Delivery: 7/67
    Rochester, NY
  6. #26
    Jun 2009
    While 5 mpg sounds terrible, my stock 230ci Tornado gets 6 at best on a good day. Gear ratio, 6,000lbs, and the areodynamics of a barn door don't help. I believe the pertronics electronic ignition will definitely help your starting, and your running, not much in the way of fuel economy tho.
  7. #27
    Mar 2013
    southern new hampshire
    i have a petronix ignition, does absolutely wonderful, starting, running, and driving. i had lack of power and poor gas mileage when i first got my truck. and my truck had it when i got it, come to find out, had nothing to do with the ignition, i had to spark plugs that would not fire no matter what you did, so i replaced them and alls good now. i would check condition of them. as for gas mileage with 2 dead holes i was getting around 4.5 mpg, firing on all cylinders and running as well as it is ever going to i am getting 5.5 to 6. so your gas mileage is not all that far off from what it should be. and as Don Carvey always told me," your truck should have no problem keeping up with everyday traffic", and darn it he was right!!! check out my thread, "am i expecting to much" hope it helps and good luck
  8. #28
    I am looking at upgrading my ignition. Would this HEI conversion be better than the pertronix kit?
  9. #29
    Seems like a Dodge distributor would make a better fit
  10. #30
    Mar 2013
    my opinion is petronics ignition, simple install, i haven't one issue with it. my truck doesn't turn over a full revalution before it running.
    68 m715, 89yj, 83 cj, 02 tj
  1. Ford 300 6cyl
    By tngreenmachine in forum Modified Tech
    Last Post: May 6th, 2011, 01:48 AM
  2. donm37 : 24 volt v8 chevy distributor
    Last Post: November 11th, 2009, 03:30 AM
  3. Need a distributor cap
    By viperman in forum Stock Tech
    Last Post: February 4th, 2008, 02:45 PM
  4. FORD 300 6cyl Question
    By Joel in forum Modified Tech Archives
    Last Post: February 5th, 2004, 09:31 PM
