Results 1 to 9 of 9
Thread: Civvy dist centrifical advance curve
    Feb 2009
    Northern California
    Default Civvy dist centrifical advance curve
    Any ideas what the proper advance curve is? I've been having problems lately with backfiring and dieseling, so bought a timing light (mine back home doesn't do me much good here!), and checked the timing, thinking it might have drifted since last time I set it. It tested perfect 5 degrees at 650rpm, but for the heck of it, played with my idle speed knob...
    450rpm: 0 BTDC
    650rpm: 5 BTDC
    800rpm: 10 BTDC
    1000rpm: 15 BTDC
    1200rpm: 20 BTDC
    1500rpm: 25ish BTDC (off the end of the scale)
    Anything higher: 27ish BTDC
    That's a pretty steep advance curve... Is that normal for these, or are my springs bad? It's a civvy dist, with the vacuum advance disconnected and capped. I'd normally expect to hit 25 degrees around 3K-4K...
    --Randy
    Feb 2009
    Northern California
    Actually, 450rpm is around -5 BTDC, rather retarded...
    --Randy
    Does that mean 5 ATDC then at 450 RPM?
    I have to look but I think i saw the curve in one of my civvy books some time back...
    Feb 2009
    Northern California
    yes, 5 ATDC. I figured it made it clearer to use a negative than switch terms.
    If the curve is right, it's the fastest advance curve I've ever seen - If it's not, I'm thinking I might need to pull it apart and make sure I don't have a broken spring. Or ignore it, as it runs pretty well.
    The backfire and dieseling are getting annoying, though... when I stop, it will diesel for about ten seconds, and stopping the dieseling by letting off the clutch creates a rather impressive (and damaging to the exhaust system, from the number of new holes it's developed) backfire. Idle is set down at 450-500rpm, so that shouldn't be causing it...
    --Randy
    I usually stand on the gas pedal if the motor runs on...not let the clutch out...
    Ill let you know if I can find it...
    If there is a fair amount of carbon buildup on the tops of the pistons, it can cause the dieseling too. Acts like a glow plug once its good and hot.
    I have no data for you...checked the source book that i thought I had seen it in and nada...sorry.
    Feb 2009
    Northern California
    Thanks for checking!
    --Randy
    Wish you were thanking me for a result...
  1. Vacuum Advance
    By rpgdeity in forum Modified Tech
    Last Post: February 27th, 2011, 06:23 PM
  2. Civy dist.
    By johnny rezny in forum Open Discussion
    Last Post: April 3rd, 2009, 07:31 PM
  3. Civy dist cap?
    Last Post: February 15th, 2009, 03:31 PM
  4. Can I go 12v and still keep 24v Dist.
    By ASHWOOD in forum Modified Tech
    Last Post: August 26th, 2008, 09:53 AM
  5. Mil. Dist. Cap
    By adk4x4 in forum Open Discussion
    Last Post: May 4th, 2007, 09:56 AM
