Old November 12th, 2009, 04:35 AM
Moderator
PseudoZone is a Soldier
Default joesco715 : M715 Generator vs one-wire Alternator
Post by joesco715 on Dec 11, 2006, 7:53pm
Folks,
I would like some advice with regards to the charging system of the 715. My 715 which has the Hercules Diesel conversion has the stock Generator.
When I had my two M37's, one of the first mods I made was to convert the charging system to a one-wire delco alternator which greatly improved the charging system on the trucks.
Does this hold true for the 715's or should I leave well-enough alone?
Thanks for any comments or suggestions!!!
Merry Christmas to all.
Old November 12th, 2009, 04:36 AM
sermis's Avatar
sermis sermis is offline
Corporal
sermis is a Soldier
Default sermis :
Re: M715 Generator vs one-wire Alternator
Post by sermis on Dec 11, 2006, 8:03pm
Running 12 or 24 volt?
Moderator
Default joesco715 :
Post by joesco715 on Dec 11, 2006, 8:07pm
24v
Moderator
Default stanman :
Post by stanman on Dec 11, 2006, 8:19pm
thats a good question. I am always worried about my generator crappin out on me.
k8icu's Avatar
k8icu k8icu is offline
Sergeant
k8icu is a Soldier
Default k8icu :
Post by k8icu on Dec 11, 2006, 10:06pm
The M715 has a altinator not a generator and voltage regulator like the M715 has. If it's working I'd leave it alone.
  #6
Moderator
Default stanman :
Post by stanman on Dec 11, 2006, 11:36pm
I thought it was a generator??? Say if it did crap out and you needed a replacement, what would you use for a replacement?
  #7
gimpyrobb's Avatar
gimpyrobb gimpyrobb is offline
Sergeant
gimpyrobb is a Soldier
Default gimpyrobb :
Post by gimpyrobb on Dec 11, 2006, 11:50pm
Mine was dead when I got it. I'm now running a 24v onewire @ 100amps. Kind of pricey at 250.00.
  #8
Moderator
Default stanman :
Post by stanman on Dec 11, 2006, 11:54pm
ouch!where do you get one of those?
  #9
Moderator
Default adk4x4 :
Post by adk4x4 on Dec 12, 2006, 8:36am
For the Technical guys, the M-715's were fitted with 28V, 60amp alternators. The difference is what's "generated" in the coil. alternating current AC or direct current DC. AC is then rectified to DC in alternaor.
The question you need to ask is what will I be doing with my 715?
- primary offroad with deep fording option -> stick with stock
-everyday driver, staying 24v not much water -> consider modern 24v alt when stock craps out.
Either way I would cross that bridge when you come to it.
Some repairs to the stock alt are not that hard or expensive either.
HTML code is On
joesco715 : Stripping vs Blasting and other ?'s PseudoZone PseudoZone - Open Archive 14 November 13th, 2009 11:54 AM
Generator gregolma715 Stock Tech 7 May 3rd, 2009 10:05 AM
generator instead of alternator fwdstuck Stock Tech 21 April 16th, 2007 07:46 PM
Alternator Hot Wire Barrman Open Discussion 13 April 2nd, 2007 03:22 PM
Swapping the generator with a 24 volt alternator......... Nuke_battlewagon Modified Tech Archives 5 April 22nd, 2004 08:36 PM
1998 - 2019
Copyright 1998-2019
