  #11
Old November 12th, 2009, 04:39 AM
k8icu's Avatar
k8icu k8icu is offline
Sergeant
k8icu is a Soldier
Default k8icu :
Re: 715 Alternator Rebuild Project Series
Post by k8icu on Oct 17, 2006, 9:12pm
More paitents than I would have.... Good work.
  #12
Moderator
PseudoZone is a Soldier
Default adk4x4 :
Post by adk4x4 on Nov 9, 2006, 11:05am
I'm back to work on the winding after a short break. Moving ahead slowly, learning things as I go. Just wanted to post something to keep the thread alive. More pics to come soon.
  #13
hiker's Avatar
hiker hiker is offline
Corporal
hiker is a Soldier
Default hiker :
Post by hiker on Nov 9, 2006, 2:17pm
Thanks for the update. Have been waiting to see more.
  #14
Moderator
Default adk4x4 :
Post by adk4x4 on Dec 12, 2006, 8:22am
The days are getting shorter and the time I devote to this project has become slim but not forgotten. The stator is almost complete.
One more leg of the winding left. I will not do this again, it was fun at first but then became a total drag.
As a followup to the rectifier install, here is a pic of the guts side of it with new insulating silicone covering the ends of the diodes.
Looks alot like it did originally.
  #15
k8icu's Avatar
Sergeant
k8icu is a Soldier
Default k8icu :
Post by k8icu on Dec 12, 2006, 9:35pm
Are the little pieces of wood to keep the red form from collapsing? What is that made out of that your winding the wire around?
  #16
Moderator
Default adk4x4 :
Post by adk4x4 on Dec 13, 2006, 8:31am
The core or the "red form" you see is made of about 20 laminations of metal sheet. This is typical for all motor/ alternators it helps with the magnetic fields generated at the rotor in this case. The wood shims are used to keep the wire in place while you wind, after all is wound a laquer is applied and that cements the whole thing together.
The stator core you see is in every 715 alt, you can see this section if you look closely at the alt you can see the laminations on the outside. Thats if it hasn't been painted ten times.
HTML code is On
adk4x4 : Leaf spring lube PseudoZone PseudoZone - Stock Tech Archive 4 December 15th, 2009 01:19 PM
adk4x4 : Alternator issues PseudoZone PseudoZone - Stock Tech Archive 5 December 15th, 2009 12:57 PM
adk4x4 : NYS registration & inspection issues PseudoZone PseudoZone - Open Archive 3 November 12th, 2009 01:56 AM
Alternator rebuild series adk4x4 Stock Tech 1 January 10th, 2007 08:09 AM
1998 - 2019
Copyright 1998-2019
