Old November 12th, 2009, 03:41 AM
Moderator
PseudoZone is a Soldier
Default seanjames : GVW
GVW
Post by seanjames on Dec 13, 2006, 12:10pm
Did a search couldn't find it. What is the GVW for a M715?
Elwenil's Avatar
Elwenil Elwenil is offline
Private 1st Class
Elwenil is a Soldier
Default elwenil :
Re: GVW
Post by elwenil on Dec 13, 2006, 12:25pm
It's on the data plates on the dash.
Moderator
Default seanjames :
Re: GVW
Post by seanjames on Dec 13, 2006, 12:36pm
Well that would of been obvious if I owned one but I am still saving money, Have one in the scope. I was curious because if is over 10,000lbs it is exempt from lift laws here in missouri. I thought most one tons are 10,000lbs. I know that some one tons are less, I think some dodge diesels are.
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
Default brute4c :
Re: GVW
Post by brute4c on Dec 13, 2006, 11:16pm
8400 for a non winch M715
8900 for a winch M715
8500 for an M725
8900 for a non winch M726
9400 for a winch M726
Moderator
Default goose :
Re: GVW
Post by goose on Dec 14, 2006, 9:13am
The GVW is what the vehicle weighs as it sits there with various equipment.
The GVWR is what the manufacturer has rated the vehicle to weigh with whatever load you can put on it. Or the max the vehicle can weigh with load.
The law you refer to is for the GVWR. Basically it was designed to exept commercial motor vehicles because once you get over 10,000 GVWR and are used in interstate commerce, your a commercial vehicle. Not very many sigle axle trucks are over 10K GVWR, typically has to be a dually before the manufacturer will rate it over.
Looking at the other link I would say the GVWR is 8900for the M715 with winch. However the M726 w/w is 9400. Thats the same frame and drivetrain, but higher rating. So I don't think there really is a rating listed by Jeep/Kaiser.
  #6
Old November 12th, 2009, 03:42 AM
Elwenil's Avatar
Private 1st Class
Default elwenil :
Re: GVW
Post by elwenil on Dec 14, 2006, 9:42am
Hmm, I wonder if the M726 didn't get different springs or something?
Also, 10K lbs and up GVWR for light duty trucks is a fairly new deal and hasn't been around very long. The new Dodge Chassis Cab can be had in a single rear wheel configuration with a GVWR of 10,200 lbs and with the dual rear wheels it goes up to a max of 12,750 lbs when properly equipped.
  #7
brute4c's Avatar
Grand Poobah
Default brute4c :
Re: GVW
Post by brute4c on Dec 14, 2006, 9:49am
The numbers I gave are the numbers given by Jeep for the G890 series for the GVWR.
The GVW numbers are:
M715:
WOW: 5500
WW: 6000
M725: 6400
M726:
WOW: 6500
WW: 7000
Payload, Cross Country, Limited:
M715, all: 2500
M725: 2000
M726 all: 2000
Payload, Highway:
M715, all: 3000
M725: 2000
M726, all: 2500
I can break that down by GVW and GVWR by each axle if needed.
  #8
Moderator
Default seanjames :
Re: GVW
Post by seanjames on Dec 14, 2006, 11:13am
Looks like the truck I'm looking at is a 724 so is the GVWR the same as ?
  #9
brute4c's Avatar
Grand Poobah
Default brute4c :
Re: GVW
Post by brute4c on Dec 14, 2006, 11:40am
M724 is listed as:
GVW, WOW: 4800
GVW, WW: 5300
GVWR Cross Country, Limited:
WOW: 8400
WW: 8900
GVWR, Highway:
WOW: 8900
WW: 9400
Payload Cross Country: 3200 for both models
Payload Highway: 3700 for both models
All of the above numbers EXCEPT the GVW include the weight of whatever body would be added to the truck and allows 400 pounds for a 2 man crew.
The GVW is without any additional body other than the cab and without the crew allowance.
HTML code is On
1998 - 2019
Copyright 1998-2019
