Old November 13th, 2009, 10:55 AM
Moderator
PseudoZone is a Soldier
Default fng : Tool Box?
Tool Box?
Post by fng on Dec 25, 2006, 12:08pm
I have a question, Specifically what is the intended use of the long, pass through storage area in front of the bed? Was there some special purpose for this, like antenna storage or something?
I think it wold be a great place to keep my Hi-Lift. Thanks, Tracy
Old November 13th, 2009, 10:56 AM
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
Default brute4c :
Re: Tool Box?
Post by brute4c on Dec 26, 2006, 10:38am
The compartment under the front of the bed is referenced in the Operators Manual as the stowage area for many of the issued items on the truck...the manual tells what the item is and then where it is stored...this description fits item that go in that compartment:
Quote:
In tool compt on R.H. or L.H. lower front side of body.
Remember the cab is called the cab and the bed is called the body....
These are the items listed for that area:
BAG, Tool, Cotton Duck, 10" x 20"
HANDLE, Jack, Flat Strip, ? x 7/8 x 20"
JACK, Mach, Dbl-Screw, 3-Ton, Ratchet Type, 9" Closed, 18" Open
WRENCH, Socket, Wheel Stud Nut, L-Hdl, 10.5" Offset, 1" Hex Opng, 24" long.
EQUIPMENT FOR WINCH EQUIPPED VEHICLES
BLOCK, Rigging, Wire Rope, Stl-Shell, Sgl-6 ? " Sheave, W/Swivel Hook, ?" Dia Rope & Under, 5-Ton Safe Work Load, OD Finish.
CHAIN, Gen Serv, Sgl-Leg, High Test Chain, 7/16-Link x 10ft Long, W/2-Grab Hook, Proof Load 11,200 lb (Type I, Grade C, Class 2
TROOP INSTALLED ITEMS
SPOUT, Can, Gasoline, Flex, Cam Type, 2.25" OD x 16' Long.
STRAP, Cargo, Tie-down, Nylon Webbing Univ Type, 1.75" Wd, 216" to 218" Lg Ratchet Buckle, W/2 Swivel Snap Hook
HTML code is On
tire change tool osut362 Modified Tech 8 May 16th, 2013 06:48 PM
clutch alignment tool Duane Open Discussion 3 January 27th, 2009 09:55 AM
Rich Brandi at Pro Tool kalikraven Open Discussion Archives 18 January 28th, 2004 01:17 PM
1998 - 2019
Copyright 1998-2019
