Old November 11th, 2009, 09:26 PM
Binford's Avatar
Binford Binford is offline
Moderator
Binford is a Soldier
Default binfordm715 : Hand throttle cable installation query
Post by binfordm715 on Aug 20, 2006, 12:28am
I picked up one of those hand throttle control T-knob deals that mounts to the dash beside the choke knob. I can't find anything in the manuals that details how that goes in. And why does it have two cables?
I know how I'm probably going to hook it up, which wouldn't be stock, but was curious how they did it and why it would have double cables.
Moderator
PseudoZone is a Soldier
Default tacomainoh :
Re: Hand throttle cable installation query
Post by tacomainoh on Aug 20, 2006, 3:23am
that sounds more like the fording shut off valve control. I'm looking at a manual that shows two cables attached to it.... looks like the two cables go to two seperate vent hoses, and it closes them off so as not to allow water into the top and bottom of the motor.
P.136 of TM 9-2320-244-20.
kwai's Avatar
kwai kwai is offline
Sergeant
kwai is a Soldier
Default kwai :
Post by kwai on Aug 20, 2006, 6:33am
the hand throttle on the 715 attaches to the gas pedal linkage. it doesn't attach to the carb directly. like taco said, the cables you have are probably actually for the fording valves.
Binford's Avatar
Moderator
Post by binfordm715 on Aug 20, 2006, 8:23am
Ahhhh.... That it's part of the fording kit makes sense! I read about that somewhere before. Well, it will work for a throttle control too.
I'm just going to rig it up as I did my 10-speed bicycle shift lever in my CJ. I hooked it up to the carburetor linkage using a couple inches of that chain stuff from a pull-chain light. That way it will pull tight, but if I had to hit the gas for some reason, it would flex. Still got to watch it when you need to slow down though! It'd be used to keep it at a high idle and for crawling over bouncy stuff where it's hard to hold your foot steady on the gas pedal.
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
Default brute4c :
Post by brute4c on Aug 21, 2006, 9:54am
I can take a pic of the hand throttle connection for you...it does connect to the gas pedal linkage in the cab so its a very short cable..and only 1.
  #6
Binford's Avatar
Moderator
Post by binfordm715 on Aug 21, 2006, 10:36am
Sure, if it's not a hassle for you, I'd love a picture of the setup. So it's not in any of the manuals? I imagine the cable would be significantly shorter if it only had to reach the pedal linkage. I could always let the cable make a long, sweeping turn behind the dash!
So in the stock setup, if you have the throttle knob set to maybe 2000 rpm, and you goose the gas pedal, does the way it's set up allow for the engine to rev up?
The way I set up the 10-speed shifter lever in my CJ was to hook the end of the cable to a 3" piece of that ball chain from a pull-chain light such as you'd see in an attic or whatever. That way the chain pulls the throttle open, but if I goose the pedal, the chain goes limp to allow the engine to speed up. Just curious if the M715 stock throttle set-up would allow for this too.
  #7
brute4c's Avatar
Grand Poobah
Default brute4c :
Post by brute4c on Aug 21, 2006, 10:45am
It will allow that revving action...basically,the cable pulls on the same pivot as the gas pedal, so wen you pull this level, the pedal goes down as well...doing the same thing with your hand as you do with your foot....so now you have the lever pulling the pedal to 10% of its travel lets say....you can still sep on the pedal to go from 10% to 100% just not lower without releasing the lever.
You can rev it with the lever just like you do with your foot....the kids have flooded mine a few times by playing with that as they like how it makes the gas pedal move without touching it.
HTML code is On
vrod02 : Hand Throttle? vrod02 PseudoZone - Open Archive 17 November 12th, 2009 02:28 AM
Hand Throttle? halftrack78 Open Discussion 14 August 11th, 2009 07:19 AM
m-715 throttle cable jaychevy420pitbill Open Discussion 5 May 26th, 2008 08:33 PM
Throttle cable porkchop Open Discussion 5 February 6th, 2008 04:56 AM
Hand Throttle? Archiver Open Discussion Archives 0 December 24th, 2006 01:29 PM
