Old November 12th, 2009, 03:44 AM
Moderator
PseudoZone is a Soldier
Default alex : Parking brake
Parking brake
Post by alex on Dec 19, 2006, 8:23pm
Hey guys could any of you give me some info on how did the parking brake came in the original m715.
when i bought mine it didnt have one and i want to know where does ti go in the stock one.
thanks.
Old November 12th, 2009, 03:45 AM
compexp's Avatar
compexp compexp is offline
Sergeant
compexp is a Soldier
Default compexp :
Re: Parking brake
Post by compexp on Dec 19, 2006, 8:42pm
It's a drum-mounted brake that attaches to the rear of the transfer case on the driver's side. If you're asking about the lever, it's a large lever with a button on top that sticks up to the left of the xfer case levers.
Jon, do you have a pic you can post?
gimpyrobb's Avatar
gimpyrobb gimpyrobb is offline
Sergeant
gimpyrobb is a Soldier
Default gimpyrobb :
Re: Parking brake
Post by gimpyrobb on Dec 19, 2006, 9:19pm
If you have everything else, I have an extra parking brake lever that Rich was talking about. LMK.
Moderator
Default alex :
Re: Parking brake
Post by alex on Dec 20, 2006, 1:55pm
I don?t have the lever, and i?m going to see about everything else...
if anyone has a picture of the mechanism that will help ...!!!
thanks...
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
Default brute4c :
Re: Parking brake
Post by brute4c on Dec 20, 2006, 2:17pm
Hmmm....what do you need pics of....the stuff on the tcase and the lever and the linkage?
Heres some to get started:
Lever and linkage mounted to passenger side of the transmission:
not the best quality, but here is a shot of the tcase with the ebrake installed on it:
Exploded view of the ebrake parts:
View showing parking brake lever, with arrow, and other shift levers in relation:
  #6
teking teking is offline
Private 1st Class
teking is a Soldier
Default teking :
Re: Parking brake
Post by teking on Dec 20, 2006, 2:28pm
thanks.
  #7
brute4c's Avatar
Grand Poobah
Default brute4c :
Re: Parking brake
Post by brute4c on Dec 20, 2006, 4:15pm
The pic teking shows above is the stock ebrake with a conversion flange to allow the rear driveshaft to run off the same output as the ebrake. This eliminates the very loud whine at speed that the stock tcase has but it isnt a stock item....normally the rear driveshaft is on the passenger side output with the ebrake on the drivers side one.
  #8
Moderator
Default sstransky :
Re: Parking brake
Post by sstransky on Dec 20, 2006, 5:28pm
Why does the drive shaft in stock form come off the right side shaft, what capability do you lose if any by connecting to center shaft.
  #9
brute4c's Avatar
Grand Poobah
Default brute4c :
Re: Parking brake
Post by brute4c on Dec 20, 2006, 5:49pm
Why it comes that way I dont know....
I do know that there is no functionality lost...I have had mine that way since 1999 and many many others have their converted too with no problems....you still get high range, low range, 2 and 4 wheel drive as before...no difference at all....except it does cut noise as noted above...from a ton at highway speed to NONE...and some say it lowers their t-case temps...
  #10
Old November 12th, 2009, 03:46 AM
Binford's Avatar
Binford Binford is offline
Moderator
Binford is a Soldier
Default binfordm715 :
Re: Parking brake
Post by binfordm715 on Dec 20, 2006, 11:59pm
The only downside to moving it that I have ever heard was a clearance issue with the stock gas tank when the rear axle is swapped out for, say, a Chevy 14-bolt. The stock axle has the differential offset to the passenger side a bit, so it is not an issue unless you swap in a rear axle with the differential centered. It may have even fit (barely). Haven't done it myself though.
I think the benefits would easily outweigh the drawbacks though.
HTML code is On
disc parking brake osut362 Modified Tech 10 May 11th, 2011 10:30 AM
luckypabst : Parking brake question LuckyPabst PseudoZone - Open Archive 8 November 11th, 2009 01:33 AM
NP205 Parking Brake Jester Modified Tech 7 January 16th, 2009 11:32 AM
Parking Brake Specs Jester Stock Tech 4 September 9th, 2008 09:06 AM
Hydro parking brake Brian Sisson Modified Tech Archives 15 January 2nd, 2004 11:46 AM
