Old May 14th, 2004, 07:36 PM
the1968jeepthing the1968jeepthing is offline
the1968jeepthing is a Soldier
Default Brian?
i was looking into fabricating some sort of guard for the rocker panels today (i already smashed both of them in pretty good) and i noticed that the frame in which to weld the guard to is pretty far under the cab. too far to really have a strong enough support.
has anyone made rock guards for their trucks? how did you mount them? pictures would be appreciated. thanks
-Brian M
Old May 14th, 2004, 07:45 PM
Nuke_Danarchy Nuke_Danarchy is offline
Nuke_Danarchy is an Observer
check out Mud Dogs
http://homepage.mac.com/m715/jeep/index.html
1969 M715
Old May 14th, 2004, 08:13 PM
Nuke_mcinfantry Nuke_mcinfantry is offline
Nuke_mcinfantry is an Observer
12" pipe is the right curve to weld on top.....
1967 M-715 (A1)
www.homepage.mac.com/ltalessi
Old May 14th, 2004, 09:12 PM
kaiserkoski kaiserkoski is offline
kaiserkoski is a Soldier
thats a hell of a question, mine are rusted out at the corners. i would like to do what you are talking abought insted of fixing the sheatmetle since it would just get thrash again. what if you make a rolecage in the cab and tie the rocker guards onto the cage????
M715,s..are a mans jeep...
Old May 14th, 2004, 09:25 PM
well how about get some schedule 80 or so 12" pipe, or 12" tube. you could cut quite a few rocker covers. weld them on top the old and brace them under the cab.
1967 M-715 (A1)
  #6
Old May 15th, 2004, 07:01 PM
i was thinking of braceing them on the cab, (cutting out the old ones and putting the beefier steel in) but i dont want to tweak my cab up when i hit rocks off road, it doesnt seem that the cab itself would hold up to all that weight being forced upon it when beating it offroad. i would rather weld it to the frame and it would double as a step to get in, and if i stuck it out just a wee bit farther than the body it would protect the doors and such from all these trees in NH.
-Brian M
  #7
Old May 15th, 2004, 07:52 PM
if you make a cage it should tie onto the frame if done correctly, becoming part of the frame, you could put alittle extra beef around the rocker guards to be safe.
HTML code is On
rocker panel slots jpsnblood Open Discussion 4 August 15th, 2009 07:22 PM
Rocker panel replacement res0wc18 Stock Tech 12 June 30th, 2009 12:43 PM
Rocker panel, cab corner replacement ??? Elliott Open Discussion 14 April 1st, 2008 10:41 AM
Pic of my rocker................ viperman Stock Tech 8 March 11th, 2008 02:17 PM
rocker panel Nuke_mcinfantry Modified Tech Archives 10 January 16th, 2004 06:55 PM
