Results 1 to 10 of 15
Thread: Hard Starting
    Default Hard Starting
    I have a 1967 Stock M-715 that recently developed a hard starting problem, it won't start without using starting fluid and today failed to start completely. It was out and running last Fri and started easy that day. Any suggestions on where to start?
    New Jersey by Philadelphia
    Anytime I experienced that it was the coil or ballast inside the stock 24 volt distributor.
    Coil and/or ballast would be a great starting point.
    Past that, is it flooding or is the bowl draining out after it is shut off?
    I believe the bowel is full, I'm thinking of starting w/the coil, any suggestions on where to get one? I see S & S Trucks has them, thanks for the help guys
    What was wierd was that my truck would have hard starting with spark; but the spark was a little weak. A few squirts of ether and it fired up all the time. Once I replaced the coil and ballast, the spark was much hotter and never had a problem again. Pull the coil and if you have the external ballast underneath the coil, check it for cracks.
    Springdale, Arkansas
    Not to hi-jack this thread but I have a question about ballast. I bought a new coil a few months ago and installed it in the dist.. There wasn't a ballast thing in there before and so I guessed the ballast was already inside the new coil. Is it possible to get the truck to run without a ballast? I've suddenly picked up a miss that I can't diagnose.
    Feb 2009
    Northern California
    The truck will run great without the ballast resistor, possibly even better than with it... until the coil burns out. Leaving the engine off with the key on is the quickest way to do this.
    --Randy
    There are 2 types of coils used in the military ignition.
    Type A uses an external resistor and is marked that an external resistor is needed, printed right on the case.
    Type B has the resistor built in and doesnt need an external...I think I remember seeing one and that it is printed to note that as well.
    Nov 2009
    Amish Country PA
    what if you are converted to 12v... How can I be sure to get the right coil?
    Sorry guys I am a greenhorn if you ever saw one
    Isthis 12 volt with the 230 engine or with a different engine?
  1. Hard top value?
    By kingjason in forum Open Discussion
    Last Post: December 16th, 2009, 10:31 PM
  2. Hard top
    By chicklin in forum Open Discussion
    Last Post: January 13th, 2009, 08:54 PM
  3. Starting problems
    By Barrman in forum Open Discussion
    Last Post: March 18th, 2008, 03:17 PM
  4. trouble starting
    By barnaby82 in forum Stock Tech
    Last Post: November 3rd, 2007, 08:04 PM
  5. Hard top
    By BulletSponge in forum Modified Tech
    Last Post: April 17th, 2007, 06:59 PM
