Page 1 of 17 1234567891011 ... LastLast
Results 1 to 10 of 168
Thread: 1967 Kaiser Jeep M-715 6BT Build
    Default 1967 Kaiser Jeep M-715 6BT Build
    Alright guys... time to start the build thread on this one..... heres the lowdown end goal and of parts I already have....
    End goal: Somewhat stock appearing M-715 (no huge tires sorry, no spring-over axle, no crazyiness unfortunately).... Daily driven capable.... steers and stops like a modern 1-ton... with just a few too many leafs. (Hence why the m715 is known also as a 5/4 ton). Motor will stay OEM power wise... (as I have a baby 11" clutch)
    1991.5 Cummins 5.9L 6BT (VE Rotary)
    1993 Ford ZF S542 5 Speed Transmission
    Married Ford Np205.. which will be twin sticked and also have my original m715 NP200 E-brake drum housing machined to fit the new NP205.
    Ford Dana 60 HP King Pin Front Axle (1988 F350)
    Ford Sterling 10.25 Rear Axle (1988 F350)
    Disc brakes in all 4 corners (sterling disc conversion)
    Hydroboost off of a 2010+ F250/350
    Enjoy the ride!
    Night I got it home off the transporter from Grand Rapids, MN...
    Back to my home base in my own shop
    Broken down and the hard top off and windshield hinged down
    OEM Dash
    Prestine bed and all the correct bumperettes and shackles
    Non-numbers matching jeep tornado 230 (oem equipment)
    Its replacement... 1991.5 Cummins VE
    Disassemble Time
    A little more intro
    Ford SBF Adapter Setup
    Ford Married NP205
    Ford ZF S542 Speed OD
    Bare bones Part 1
    Back from the steam wash bay
    Time to start putting things back together
    Of course... nice to sprinkle some tech in there too.... CAD of course !
    A little more intro part II
    Dash Concept in CAD
    Nov 2009
    Greenwood, Indiana
    Keep it coming venom!
    Thanks, George
    Joshua 24:15
    Sep 2007
    Upstate NY
    Are you planning a cross member under the 6bt? Looking forward to your progress!
    Quote Originally Posted by osok View Post
    No.... OEM frames are strong enough if your not rock bouncing them... *MOST* guys who put in 6BT's do not.... if I was upping the power from OEM (which I'm not) and had a transmission that could take it... I would indeed brace the frame underneath.
    Since I'm remaining stock in my engine, and my ford ZF transmission only has an 11" clutch.... frame spreading will not be of any concern...
    Sep 2007
    Upstate NY
    I am also interested in your plumbing of the hydroboost to cummins PS pump and what steering box you are going with. I have a similar set up with a FSJ box that I am hoping will have enough flow to turn 39's. I am holding off on the crossmember until I notice a problem, thanks for the input.
    Out with the old... in with the "new" front axle
    Old 5.86 ratio closed knuckle dana 60 with drums.... in with the new King Pin, High-Pinion Ford F350 Dana 60 with discs....
    The Sterling 10.25 Rear as I bought it....
    Got me a Kingpin 60
    Sneaking it in....
    why didn't you sterilize the new axle of all the old brackets and mounts before you put it inder the m715 ?
    Sep 2007
    Upstate NY
    drivers side front diff will make routing your exhaust easier with the 6bt.
    Looking good, keep the pics coming!
