A little more intro part II
Dash Concept in CAD
Dash Concept in CAD
Keep it coming venom!
Thanks, George
Joshua 24:15
Are you planning a cross member under the 6bt? Looking forward to your progress!
No.... OEM frames are strong enough if your not rock bouncing them... *MOST* guys who put in 6BT's do not.... if I was upping the power from OEM (which I'm not) and had a transmission that could take it... I would indeed brace the frame underneath.
Since I'm remaining stock in my engine, and my ford ZF transmission only has an 11" clutch.... frame spreading will not be of any concern...
I am also interested in your plumbing of the hydroboost to cummins PS pump and what steering box you are going with. I have a similar set up with a FSJ box that I am hoping will have enough flow to turn 39's. I am holding off on the crossmember until I notice a problem, thanks for the input.
Out with the old... in with the "new" front axle
Old 5.86 ratio closed knuckle dana 60 with drums.... in with the new King Pin, High-Pinion Ford F350 Dana 60 with discs....
The Sterling 10.25 Rear as I bought it....
Got me a Kingpin 60
Sneaking it in....
why didn't you sterilize the new axle of all the old brackets and mounts before you put it inder the m715 ?
