Results 11 to 20 of 23
Thread: My new rocker panels
  1. #11
    Jun 2017
    Louisville, Kentucky
    Quote Originally Posted by Jonnie View Post
    Omg those look great!!
    Dan is very good!
  2. #12
    I would definitely be interested in a set if he is going to knock out a few.
    Is it possible make them longer to accommodate fashioning new cab corners also?
  3. #13
    Although I am lucky enough to have good rockers at the present time, I'd probably buy a set to satisfy the hoarder in me.
    I do understand that it will probably be a small run and your friend will want to be paid for is time invested.
    Roy
  4. #14
    Oct 2016
    Dracut, Massachusetts
    I'd certainly be interested in a set too.
  5. #15
    Jun 2017
    We are test fitting them right now. Boy the are trying out great. I'm about to post pictures.
  6. #16
    Jun 2017
    Jun 2017
    I talked to Dan. He says that he can sell them for $100 plus shipping per set. But there are a couple things that you need to know.
    1 is that they are 18 gauge so they are stronger than the stock rockers.
    And the other is that he made these to be direct replacements but it's still not an easy job. The installer should really know metal. The original spot welds have to be drilled out and each rocker will need to be massaged into place according to how much metal your replacing and have cut out.
    Let me know what you guys think.
  8. #18
    Quote Originally Posted by Freakshow View Post
    That was the same for the rockers that were available years ago. You need to know metal work.
  9. #19
    Default rockers
    I think I could use a set but to make sure I will look and get back to you
  10. #20
    Sep 2014
    Southern New Hampshire
    I'm pretty sure 18g was stock, I know I wouldn't accept anything less, the poor aftermarket replacements are 20g and they're on the thin side. I would definitely love a set.
    Sent from my SM-S920L using Tapatalk
