Results 1 to 4 of 4
Thread: rear driveshaft relocation
    Sep 2016
    SW New Hampshire
    Default rear driveshaft relocation
    Hello, been doing a lot of work to get my M725 on the road. One question that I can't find. If the rear driveshaft is re-located to the output with the emergency brake, will this output also be in low gear when the np 200 is put in low?
    Thanks, Wayne
    Sep 2014
    Wichita Falls, TX
    Yes. All same same. Both rear outputs function the same.
    Sep 2016
    SW New Hampshire
    Thanks Von. It was just one of those things I wasn't sure of.
    Wayne
    That is correct...changing the location of the output driveshaft to the left or right output location, the tcase works the exact same.
    The only change is that the prominent whine from the stock tcase disappears when the driveshaft is moved.
    Some have claimed that is also helps with the notorious overheating at higher speeds/rpms that the NP200 has...In my experience, using synthetic lube and with a temp gauge plumbed to the tcase, when the swap happened, there was no appreciable change in temps noted.
