  #111
Old September 9th, 2018, 07:47 AM
Von's Avatar
Von Von is offline
Corporal
Von is a Soldier
Schweeeet.
  #112
Old September 10th, 2018, 08:04 AM
12998's Avatar
12998 12998 is offline
12998 is a Soldier
Looks like someone has been active ...
I like how it is turning out.
Any more details that you can share with the tank swap?
Specifically what did you use for mounting it, what application
was it from, and what did you use for the sending unit?
How are you planning on routing the fill?
Paul
1967 M715 7.3 diesel 5spd ...
  #113
Old September 19th, 2018, 03:36 PM
venominjected's Avatar
Corporal
venominjected is a Soldier
Paul
The tank was purchased new and is for a 1985 Chevy K5 Blazer
It is 26 gallon (there is also a 31 gallon option)
I made a "cage" for it and suspended it under the frame rails...
For a sending unit I am using the factory 1985 Chevy K5 Blazer with the 6.2L diesel option... this sending unit has a pickup and return line as well as a vent built in...
The gauges I will be running in this truck can "select" which OHM setting is needed so i really dont care if its 0-90Ohm full or 30-240 etc. or 12 volts vs 24.
For filling I pretty much plan on routing the fuel hose between the bed floor and above the frame rail as there is already a very large gap there.
I may relocate the OEM fuel fill to behind the rear fenderwell instead of in front... or simply add another fuel door there. Unsure yet but I think I've seen both done on m715's before.
  #114
Old September 22nd, 2018, 11:13 AM
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
WOW!!!!!!!!!!!
Way to save a thread Sir!
Hats off to ya both one the relinking AND the great build...something this good should NOT be lost ever!!!!
  #115
Old September 22nd, 2018, 01:36 PM
jhartings is a Soldier
Default Nice work!
Inspiring work. Top notch. Thanks for sharing.
  #116
Old November 20th, 2018, 07:37 AM
12998's Avatar
12998 is a Soldier
Thanks for the tank info.
Just ordered mine, pretty much going to copy what you did.
Its going to be one of the winter projects.
Paul
  #117
Old December 21st, 2018, 08:37 PM
Corporal
Front Dana 60 Kingpin front axle replacement for the m715 (out of a 88' F350) complete... onto reinstall and begin wiring and brake lines.
The day I found it :BEFORE:
DURING:
AFTERNew inner axle seals, new bearings, new hub seals, new U-joints, new calipers, new rotors, new kingpin bushings, new lockouts)
  #118
Old January 10th, 2019, 11:41 AM
Corporal
Front Dana 60 now complete entirely(calipers and tie rod now on)...
Cab back off for 4" exhaust and brakeline routing.
  #119
Old January 10th, 2019, 11:49 AM
Corporal
Working on rear backup and bumper end markers
2010 Duramax hydroboost final install with a new MC along with the hydraulic clutch master cylinder (new 90's Ford ZF5 master cylinder) along with hooked up to OEM pedals.
  #120
Old January 10th, 2019, 04:57 PM
Soooooo jealous. Amazing work and pics.
